pimpleFoam LES y+ and wall functions
Old   January 16, 2014, 05:43
Default pimpleFoam LES y+ and wall functions
Pj.
Luca
Pj. is on a distinguished road
Hi everybody,
i did a quick search but i could find an answer to this pretty basic question.
I'm running a case trying to reproduce the flow inside a wind tunnel. I'm running it with pimpleFoam and LES turbulence model.
the first problem is about the correct way to compute y+. Using the yPlusLES tool it says that the maximum y+ on my object (a building inside the WT) is about 200.
Since my firt cell is 0.7mm thick I did some calculation and, using
this would mean that at the centre of the first cell u is 420 m/s while u is never bigger than 24m/s (paraview says) in my domain.
Reversing those formulas to compute y+ i found it to be about 20-30 in the worst case scenario.
Which y+ is the correct one? Mine or the yPlusLES one?
______________________________________
Once I figure which y+ is correct, which are the corrects boundary conditions for U, p, nuSgs and nuTilda on a wall patch?
I found this topic, but it only says to try to have y+<7 wich is quite hard for me to obtain since it would mean to have a layer approximately 0.15mm thick that would cause courants to be huge (moreover i'm having some troubles with snappyHex adding more than 8 layers, but this is discussed in another topic)
Thank you very much
Pj. is offline   Reply With Quote
Old   January 16, 2014, 08:00
okroud is on a distinguished road
Have you already taken a look at the y+ values with paraFoam?
1. Are all y+ values on your Object of this magnitude?
2. Is it just one single spot and where is it located?
In the second case you should check the mesh at this point.
PS:
I get the same results for u in the first cell center for y=0.0007 in the first formula.
But shouldn't you set
y = 0.0007/2 = 0.00035
since the wall distance is not the size of your cell, but the distance to the first cell centre? I'm not sure about that... (This would just reinforce your problem anyway).
okroud
okroud is offline   Reply With Quote
Old   January 16, 2014, 11:18
Pj.
Luca
The problem only occurs in a small spot (see picture) where the velocity isn't too big and where the mesh looks pretty much ok.
PS: the real maximum shown by the yPlusLES utily is indeed in a very small spot. In the picture the red area has an y+ of about 100-110
Old   January 16, 2014, 12:31
Regarding the pictures the problem seems to be global. Y+ not 100 everywhere but still much more than expected.
An alternative way to calculate the gradient normal to the wall \frac{\partial{u}}{\partial{y}} is to use the tool wallGradU. Execute this tool, then open your case in paraView and calculate y+ with your cell-size and the formulas of your first post. This should be a good comparison to the yPlusLES tool.
Wall functions - questions about implementation AlmostSurelyRob OpenFOAM Programming & Development 44 May 6, 2020 11:11
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 12:55
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
LES automatic wall function Sungho Yoon CFX 7 October 9, 2008 08:00
Wall functions John Grimm Main CFD Forum 13 February 1, 2002 19:34
