pipeCyclic tutorial codeStream error in codedFixedValue BC specification
Old   January 15, 2014, 23:36
Default pipeCyclic tutorial codeStream error in codedFixedValue BC specification
Ralph Aldredge
fivewood is on a distinguished road
I get the following errors when running decomposePar -cellDist. Any help would be greatly appreciated.
/Volumes/OpenFOAM-v2.2.2/aldredge-2.2.2/run/incompressible/simpleFoam/pipeCyclic/0/U.boundaryField.inlet.#codeStream:58:35: error: invalid use of 'this' in non-member function
/Volumes/OpenFOAM-v2.2.2/aldredge-2.2.2/run/incompressible/simpleFoam/pipeCyclic/0/U.boundaryField.inlet.#codeStream:60:29: error: no matching function for call to 'operator==(Foam::vectorField&)'
/Volumes/OpenFOAM-v2.2.2/aldredge-2.2.2/run/incompressible/simpleFoam/pipeCyclic/0/U.boundaryField.inlet.#codeStream:60:29: note: candidate is:
/Users/aldredge/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/VectorSpaceI.H:634:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam:perator==(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&)
make: *** [Make/darwinIntel64Gcc46DPOpt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_8d6280772013f7e6aea251f1c3fca7b6b529d0d9/platforms/darwinIntel64Gcc46DPOpt/lib/libcodeStream_8d6280772013f7e6aea251f1c3fca7b6b529 d0d9.dylib"
file: /Volumes/OpenFOAM-v2.2.2/aldredge-2.2.2/run/incompressible/simpleFoam/pipeCyclic/0/U.boundaryField.inlet from line 28 to line 29.
From function functionEntries::codeStream::execute(..)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 196.
My U file is:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
//- Set patchGroups for constraint patches
#include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes"
inlet
type codedFixedValue;
redirectType swirl;
#codeStream
codeInclude
#include "vectorField.H"
code
const vector axis(1, 0, 0);
vectorField v(2.0*this->patch().Cf() ^ axis);
v.replace(vector::X, 1.0);
operator==(v);
value $internalField;
outlet
type inletOutlet;
inletValue $internalField;
walls
type fixedValue;
value uniform (0 0 0);
fivewood is offline   Reply With Quote
