Flow around cylinder at Re=40
Old   January 14, 2014, 23:04
Default Flow around cylinder at Re=40
leeminjae
leeminjae is on a distinguished road
Hello ladies & gentlemen
I'm working to simulate "flow around cylinder at Re=40"
I generated the mesh using Gambit.
It's a very simple simulation.
the objective of simulation is to get a good matching results of Cd & Cl
But I think my result is not that matching with an another paper.
I don't know what's wrong.
I attached my code below.
And another problem, Co(Courant Number) is around 1.6
Is it O.K ?
The property I used
Ux 0.071576 (m/s)
Diameter 0.01 (m)
Nu 1.7894e-05
Re 40
I'm sorry to attach my file not comfortably.
I don't know how to attach my code with files.
I'm looking forward to taking advice from you.
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
forceCoeffs1
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl outputTime;
log yes;
patches ( cy );
pName p;
UName U;
rhoName rhoInf; // Indicates incompressible
log true;
rhoInf 1.225; // Redundant for incompressible
liftDir (0 1 0);
dragDir (1 0 0);
CofR (0 0 0); // Axle midpoint on ground
pitchAxis (0 0 1);
magUInf 0.4;
lRef 0.01; // Wheelbase length
Aref 0.0001; // Estimated
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
down
type symmetryPlane;
up
type symmetryPlane;
wall
type zeroGradient;
back
type symmetryPlane;
front
type symmetryPlane;
outlet
type fixedValue;
value uniform 0;
inlet
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
down
type symmetryPlane;
up
type symmetryPlane;
wall
type fixedValue;
value uniform (0 0 0);
back
type symmetryPlane;
front
type symmetryPlane;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (0.071576 0 0);
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
libs
"libOpenFOAM.so"
"libincompressibleTurbulenceModel.so"
"libincompressibleRASModels.so"
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 150;
deltaT 0.005;
writeControl timeStep;
writeInterval 200;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
#include "forceCoeffs"
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default backward;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear orthogonal;
laplacian((1|A(U)),p) Gauss linear orthogonal;
interpolationSchemes
default linear;
interpolate(HbyA) linear;
snGradSchemes
default orthogonal;
fluxRequired
default no;
p ;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
leeminjae is offline   Reply With Quote
Old   January 16, 2014, 22:22
Josh
joshm is on a distinguished road
This could be any number of issues. If you post your case as a zip file, people might take a look at it for you.
joshm is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 03:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 14:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 27, 2007 00:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
