January 13, 2014, 13:57 |
SimpleFoam time step continuity error
Josh
Hi all,
Firstly, I'm pretty new to OF so please forgive me if I'm doing something really stupid. I'm trying to run simpleFoam on a structured O-grid mesh of an aerofoil, generated using this tool: http://hvirvel.dk/airfoilmesher/ with coordinates that I've put in as a .dat file. However, when I run I'm getting an error in which my time step continuity errors are exploding, as is the bounding nuTilda value. The error message is as follows: --- Time = 51 smoothSolver: Solving for Ux, Initial residual = 0.545925, Final residual = 0.0316233, No Iterations 40 smoothSolver: Solving for Uy, Initial residual = 0.529254, Final residual = 0.0427123, No Iterations 38 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 Uninterpreted: #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const at ??:? #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #7 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #9 at ??:? #10 at ??:? #11 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #12 at ??:? Floating point exception (core dumped) --- I have searched and tried the following: - Setting gradSchemes in fvSchemes to cellLimited 1. This then causes the simulation to not explode, but it does not converge; it diverges very slowly. After time = 5000 it was still nowhere near converged. - Running with turbulence off. This obviously removes the nuTilda exploding, but the time step continuity errors still explode. - Using a coarser mesh. This speeds up the error message appearing, but still doesn't fix the problem. Using an unstructured mesh using gmsh with all the boundary conditions in the 0 folder the same works fine, and converges no problem. I can't work out what exactly is causing the problem, and any help or suggestions would be greatly appreciated. My files are all in the zip file here: https://www.dropbox.com/s/hcyfj9yby0...structured.zip Thanks in advance for any help anyone can give. |
August 8, 2014, 03:59 |
harshawardhank
Rep Power: 13 |
Have you solved your problem?????
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
