Uniform pressure in chtMultiRegionFoam
Old   January 13, 2014, 13:23
Default Uniform pressure in chtMultiRegionFoam
Vincent Leroy
leroyv is on a distinguished road
Dear all,
I'm currently trying to get chtMultiRegionFoam working to simulate the cooling of a hot square beam by air. The configuration is the following:
  • a square-cross-section beam is inserted into a 2D canal filled with air
  • flow enters the canal at a given pressure, velocity and temperature
I set up a chtMultiRegionFoam case, and I paid attention to the boundary and initial conditions. The solver runs well, but the results are intriguing: the pressure field remains uniform, unlike in the PlaneWall2D tutorial for chtMultiRagionSimpleFoam.
Do you people have an idea of what it might come from?
Cheers,
Vincent
leroyv is offline   Reply With Quote
Old   January 16, 2014, 12:19
Smile Answer
Vincent Leroy
Answering to myself: pressure actually happens not to be uniform. I had just chosen a case such that it ranged around 1e5 Pa +- 1e-5. This couldn't be displayed by Paraview, even with proper output precision.
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
boundary conditions for simpleFoam calculation foam_noob OpenFOAM Running, Solving & CFD 8 July 1, 2015 09:07
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 16:12
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
