2 region with varied properties
Old   January 11, 2014, 15:58
Default 2 region with varied properties
erik gustafsson
guserik is on a distinguished road
I try to simulate reduction of pressure in an air tank with rhoPimpleFoam. In the air tank the pressure is 9 bar and the surrounding is 1 atm. I got problem with the solver in the begining of the simulation for T < 0.001 s. i think this is related to a small region with high pressure gradients initial. I dont know if there is any ways around this issue? The error message is shown below. My temperature diverge completely. I use rhomin rhomax 100 and 0.5 kg/m3
From function janafThermo<EquationOfState>::limit(const scalar T) const
in file /disk/sw/OpenFOAM/OpenFOAM-2.2.2/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 4.45601e+12
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 6.61456e+12
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 5.04776e+08
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 159931
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 1.01122e+14
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 1.06274e+07
--> FOAM Warning :
guserik is offline   Reply With Quote
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
[Other] Material properties in multi region foam and refining mesh for each region mukut OpenFOAM Meshing & Mesh Conversion 2 October 7, 2013 03:08
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
