January 10, 2014, 15:59 |
interFoam: No finite volume options present
CFDGuy
Rep Power: 13 |
Hi Foamers,
When I run interFoam on a cluster I got the following output: Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading g Calculating field g.h No finite volume options present time step continuity errors : sum local = 0.0592593, global = -0.0592593, cumulative = -0.0592593 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.78695e-11, No Iterations 221 time step continuity errors : sum local = 5.71578e-12, global = 4.65865e-14, cumulative = -0.0592593 Courant Number mean: 12.7285 max: 41.8982 Starting time loop ----- "No finite volume options present" what does this phrase mean? Does it have any effect on cpu time ? Thanks |
January 12, 2014, 08:37 |
Anton Kidess
Rep Power: 30 |
I'm guessing you are running a case without an fvOptions file. Shouldn't be a problem, just ignore the warning.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
July 14, 2014, 04:57 |
Vignesh
Rep Power: 14 |
Dear Friends !!
I recently modified the surface tension force implementation in the interfoam solver and successfully compiled it. But when i run a case using this solver i get error as shown in the snapshot. The modification i made was instead of I made the changes in PEqn.H file in interfoam directory and the modified code is shown below (modifications are written in bold) Code:
{ /* New one to calculate laplacian of alpha*/ volScalarField lapalpha(fvc::laplacian(alpha1)); /* New one to calculate laplacian of alpha*/ volVectorField HbyA("HbyA", U); HbyA = rAU*UEqn.H(); surfaceScalarField phiHbyA ( "phiHbyA", (fvc::interpolate(HbyA) & mesh.Sf()) + fvc::ddtPhiCorr(rAU, rho, U, phi) ); adjustPhi(phiHbyA, U, p_rgh); phi = phiHbyA; surfaceScalarField phig ( ( fvc::interpolate(lapalpha)*interface.sigma()*interface.nHatf() - ghf*fvc::snGrad(rho) )*rAUf*mesh.magSf() ); phiHbyA += phig; while (pimple.correctNonOrthogonal()) { fvScalarMatrix p_rghEqn ( fvm::laplacian(rAUf, p_rgh) == fvc::div(phiHbyA) ); p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell)); p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter()))); if (pimple.finalNonOrthogonalIter()) { phi = phiHbyA - p_rghEqn.flux(); U = HbyA + rAU*fvc::reconstruct((phig - p_rghEqn.flux())/rAUf); U.correctBoundaryConditions(); fvOptions.correct(U); } } #include "continuityErrs.H" p == p_rgh + rho*gh; if (p_rgh.needReference()) { p += dimensionedScalar ( "p", p.dimensions(), pRefValue - getRefCellValue(p, pRefCell) ); p_rgh = p - rho*gh; } }
Thanks and Regards Vignesh |
July 15, 2014, 05:57 |
Albrecht vBoetticher
Rep Power: 17 |
I bet you devide by zero in some cells, yust give it a try with lapalpha(alpha1) with alpha1 > 0 in all cells to try it out.
July 15, 2014, 12:05 |
Vignesh
Rep Power: 14 |
Thank you Albrecht !! I found the error and corrected it
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
About finite volume methods for N-S | Lionel BRS | Main CFD Forum | 6 | July 16, 2006 04:15 |
Finite Element vs. Finite Volume Codes | Salman | Main CFD Forum | 9 | January 6, 2006 23:59 |
control volume based finite element | araz | Main CFD Forum | 1 | November 15, 2003 18:50 |
