Simulating turbulent flow in rectangle pipe with rhoPimpleFoam |
赵庆良
Rep Power: 13 ![]() |
Hi foamers,
I want to use rhoPimpleFoam to simulate turbulent flow in rectangle piple.here is my mesh,it is simple. mesh.jpg The length is 200mm,width and high is 25mm.The detail is in blockMeshdict. Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) (0.2 0 0) (0.2 0.025 0) (0 0.025 0) (0 0 0.025) (0.2 0 0.025) (0.2 0.025 0.025) (0 0.025 0.025) ); blocks ( hex (0 1 2 3 4 5 6 7) (100 20 20) simpleGrading (1 1 1) ); edges ( ); boundary ( bottomWall { type wall; faces ((0 4 5 1)); } topWall { type wall; faces ((7 6 2 3)); } sides1 { type wall; faces ((7 4 5 6)); } sides2 { type wall; faces ((3 0 1 2)); } in { type patch; faces ((0 4 7 3)); } out { type patch; faces ((1 5 6 2)); } ); mergePatchPairs ( ); Code:
dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform (0 0 0); boundaryField { bottomWall { type fixedValue; value uniform (0 0 0); } topWall { type fixedValue; value uniform (0 0 0); } sides1 { type fixedValue; value uniform (0 0 0); } sides2 { type fixedValue; value uniform (0 0 0); } in { type turbulentInlet; referenceField uniform (1 0 0); fluctuationScale (0.1 0.1 0.1); value uniform (1 0 0); } out { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } } time0.jpg Then I run my case,and I write out a result at every 20 deltaT(The first result is time=0.002).Picture "time1" is U field at time=0.002. time1.jpg Please take a look at time1 picture carefully.Just after 0.002s,the outlet's velocity is nearly 1m/s,same as initial vilocity I defined firstly. Actually,it is unphysical.Because 1m/s*0.002s=2mm.And the mesh length is 200mm,it is impossible that after 0.002s,outlet's velocity is nearly 1m/s. Could some one tell me that where I was wrong?What cause the problem? |
HECKMANN Frédéric
Rep Power: 17 ![]() |
Put your full case here, it will be easier to check
LES turbulent pipe flow | panara | OpenFOAM Running, Solving & CFD | 68 | January 26, 2023 11:34 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow | florian_krause | OpenFOAM | 3 | December 1, 2012 04:11 |
Roughness in turbulent pipe flow | 1000sh | Main CFD Forum | 3 | April 11, 2010 09:00 |
Simulating fully developed flow in a pipe | Tim Donohue | CFX | 1 | November 20, 2007 20:24 |
