simpleFoam Floating point error (Core Dumped)
Old   December 24, 2013, 04:23
Post simpleFoam Floating point error (Core Dumped)
sam.ho is on a distinguished road
Hi
I am simulating a flow valve with following parameters
Density = 830 [kg/m3]
Viscosity = 8.26e-06 [kg/m.s]
Mass Flow rate = 145 lph (litres per hr)
Re=1.87202 X 10^5
The valve has one inlet and 4 outlets.
The boundary conditions are as follow
U file
[dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
INLET
type flowRateInletVelocity;
volumetricFlowRate constant 40.6e-6;
value uniform (0 0 0);
OUTLET_1
type inletOutlet;
inletValue uniform (0 0 0);
OUTLET_2
type inletOutlet;
OUTLET_3
type inletOutlet;
OUTLET_4
type inletOutlet;
WALL_VALVE
type fixedValue;
WALL_SPRING
type fixedValue;
WALL_HOUSING
type fixedValue;
WALL_SPRING_SUPPORT
type fixedValue;
p file
[CODE]
[dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type zeroGradient;
OUTLET_1
type fixedValue;
value $internalField;
OUTLET_2
type fixedValue;
OUTLET_3
type fixedValue;
OUTLET_4
type fixedValue;
WALL_VALVE
type zeroGradient;
WALL_SPRING
type zeroGradient;
WALL_HOUSING
type zeroGradient;
WALL_SPRING_SUPPORT
type zeroGradient;
k file
[CODE]
[dimensions [ 0 2 -2 0 0 0 0 ];
internalField uniform 0.0001133785;
boundaryField
INLET
type turbulentIntensityKineticEnergyInlet;
intensity 0.0322;
value uniform 0.0001133785;
OUTLET_1
type inletOutlet;
inletValue uniform 0.0001133785;
OUTLET_2
type inletOutlet;
OUTLET_3
type inletOutlet;
OUTLET_4
type inletOutlet;
WALL_VALVE
type kqRWallFunction;
WALL_SPRING
WALL_HOUSING
WALL_SPRING_SUPPORT
Epsilon file
[CODE]
[dimensions [ 0 2 -3 0 0 0 0 ];
internalField uniform 0.01533;
boundaryField
INLET
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.001; // This is based on diameter
value uniform 0.0153;
OUTLET_1
type inletOutlet;
inletValue uniform 0.0153;
OUTLET_2
type inletOutlet;
OUTLET_3
type inletOutlet;
OUTLET_4
type inletOutlet;
WALL_VALVE
type epsilonWallFunction;
WALL_SPRING
WALL_HOUSING
WALL_SPRING_SUPPORT
controlDict file
[CODE]
[application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 0.1;
writeControl timeStep;
writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 8;
runTimeModifiable true;
fvSchemes file
[CODE]
[ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
div(phi,k) bounded Gauss upwind;
div(phi,epsilon) bounded Gauss upwind;
div(phi,R) bounded Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
fvSolutions
[CODE][solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-08;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-08;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-08;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-08;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 3;
pRefCell 0;
pRefValue 0;
residualControl
p 1e-2;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.2;
equations
U 0.2;
k 0.2;
epsilon 0.2;
R 0.2;
nuTilda 0.2;
Snap shots of mesh and Velocity profile is attached. When i run simulation it ran up to 5.3 after that we got floating point error (core Dumped) message.Preceding the bounding epsilon problem.
Please Help me to get this simulation.
File Type: jpg Screenshot from 2013-12-24 11:30:00.jpg (73.3 KB, 18 views)
File Type: jpg Screenshot from 2013-12-24 12:09:41.jpg (57.4 KB, 17 views)
sam.ho is offline   Reply With Quote
Old   December 25, 2013, 21:21
Awais Ali
owayz is on a distinguished road
Send a message via MSN to owayz
Hi Sam.ho,
This post is not the solution to your problem. But an advise that might help others to help you. Always test your setup with simple model test cases before proceeding towards the solution of your actual problem. It could be easier to catch the problems in a simple test problem, where you don't have so many boundary conditions and complex setup options.
Always post the error with files "(i.e. setup (+case) or test case)" with which you encounter the problem. If you can't share the full problem make a small test case demonstrating the problem. That might help others to find the problem and help you. Or may be you will solve the problem yourself in y process to make a test case.
Best Regards,
Ali
owayz is offline   Reply With Quote
Old   December 31, 2013, 07:57
Hi owayz,
I have simulated simple cases like flow past circular cylinder and square cylinder and i got satisfactory results.
But if i apply the similar concept here I am getting error ?
Can anybody suggest a solution ?
What is causing this simpleFoam floating point exception? pajot OpenFOAM Running, Solving & CFD 15 April 20, 2018 04:39
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
Floating point exception (core dumped) Punt3r OpenFOAM Running, Solving & CFD 1 September 3, 2013 09:51
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
Floating point error (core dumped) sihaqqi OpenFOAM Post-Processing 1 April 17, 2013 07:57
