nCorrector, nOuterCorrectors and maxCo number
Old   December 19, 2013, 01:13
Default nCorrector, nOuterCorrectors and maxCo number
kkpal is on a distinguished road
hello, foamers.
In my experience with pimpleFoam, I found out that nCorrector and nOuterCorrector specified in fvSolution file helps to stabilize the simulation when a large maxCo is used. Firstly I set nCorretor=2, nOuterCorrector=3 and maxCo=2, the simulation failed after it struggled for some iterations. Then I changed only the nCorrector = 3, it runs sucessfully.
I'm told nCorrector is the number of iterations of pressure equation(in my case GAMG) with in a PISO algorithm and nOuterCorrctor is the number of PISO iterations within the PIMPLE algorithm.
As I have observed, increasing the nCorr and nOuterCorr did not increase the total iterations in GAMG or PIMPLE iteration too much, however it helped stabilize the simulation with bigger courant number and hence reduced the total simulation time.
Am I correct about what I said above?
kkpal is offline   Reply With Quote
Problems with adjustable timestep control and maxCo Number wolle1982 OpenFOAM Running, Solving & CFD 5 September 24, 2015 11:07
maxCo or whatever.. eternityboy OpenFOAM 5 July 7, 2014 10:59
sudden overflow of the courant number kkpal OpenFOAM Running, Solving & CFD 0 July 3, 2013 08:54
maxco and icoFoam m5m5kh OpenFOAM Running, Solving & CFD 3 March 9, 2013 11:17
solving with Courant Number became larger and larger whyingwang OpenFOAM Running, Solving & CFD 4 November 7, 2012 19:43
