turbulenceProperties Dictionary turbulence setting |
December 15, 2013, 09:26 |
Good day All I have reviewed documentation and this forum and cannot find a description / purpose of the turbulence entry in the turbulenceProperties file. Could someone confirm the purpose of the following entry?
turbulence off |
December 16, 2013, 03:24 |
Bernhard
Rep Power: 22 |
The latter one. The solvers that allow turbulence models (i.e. pisoFoam), needs to know whether or not it should use one.
December 16, 2013, 09:54 |
Icaro A. Accordi
Rep Power: 16 |
This makes the turbulence model to work as laminar but copy the turbulence files (k, epsilon, omega, etc) to time folders. It is good to inicialize a flow as laminar and continue it as turbulente.
turbulence off, turbulenceproperties |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Residual level setting of Fluent | lhlh | ANSYS | 2 | November 17, 2012 22:35 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 12:35 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 05:24 |
