Foam::error::printStack(Foam::Ostream&) in reactingFoam |
December 12, 2013, 10:59 |
Rep Power: 12 |
Hello I am using OpenFoam 2.2.2 combined with swak4Foam 0.2.4. I have the following error. I searched for the libraries which are named in the error and these are available in the lib folder of OpenFoam and swak4Foam. I also checked whether epsilon or k is zero in the boundary conditions. Maybe it is a problem with compiling? Do anyone know the solution to this failure?
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : reactingFoam Date : Dec 12 2013 Time : 14:43:22 Host : "Martin" PID : 7490 Case : /home/martin/OpenFOAM/martin-2.2.2/run/tutorials/combustion/reactingFoam/ras/Versuche_LVA/2_Versuch nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libOpenFoam.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libOpenFoam.so" Create mesh for time = 0 Reading g Creating reaction model Selecting combustion model PaSR<psiChemistryCombustion> Selecting chemistry type { chemistrySolver ode; chemistryThermo psi; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader chemistryModel: Number of species = 5 and reactions = 1 Selecting ODE solver KRR4 Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type RASModel Selecting RAS turbulence model realizableKE realizableKECoeffs { Cmu 0.09; A0 4; C2 1.9; alphak 1; alphaEps 0.833333; alphah 1; sigmak 1; sigmaEps 1.2; Prt 1; } Creating field dpdt Creating field kinetic energy K No finite volume options present Courant Number mean: 0.000851523 max: 5.63169 Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader Creating expression field CRRv ...swak4Foam: Allocating new repository for sampledMeshes swak4Foam: Allocating new repository for sampledGlobalVariables "Loaded plugin functions for 'FieldValueExpressionDriver':" rhoTurb_R: "volSymmTensorField rhoTurb_R()" rhoTurb_alphaEff: "volScalarField rhoTurb_alphaEff()" rhoTurb_devRhoReff: "volSymmTensorField rhoTurb_devRhoReff()" rhoTurb_epsilon: "volScalarField rhoTurb_epsilon()" rhoTurb_k: "volScalarField rhoTurb_k()" rhoTurb_muEff: "volScalarField rhoTurb_muEff()" rhoTurb_mut: "volScalarField rhoTurb_mut()" thermo_Cp: "volScalarField thermo_Cp()" thermo_Cv: "volScalarField thermo_Cv()" thermo_T: "volScalarField thermo_T()" thermo_alpha: "volScalarField thermo_alpha()" thermo_hc: "volScalarField thermo_hc()" thermo_he: "volScalarField thermo_he()" thermo_mu: "volScalarField thermo_mu()" thermo_p: "volScalarField thermo_p()" thermo_psi: "volScalarField thermo_psi()" thermo_rho: "volScalarField thermo_rho()" swak4Foam: Setting default mesh type:volScalarField Creating expression field CRRp ... type:volScalarField Creating expression field al ... type:volScalarField PIMPLE: Operating solver in PISO mode Starting time loop Courant Number mean: 2.93629e-05 max: 0.194196 deltaT = 6.89655e-05 Time = 6.89655e-05 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for O2, Initial residual = 1, Final residual = 5.38976e-07, No Iterations 20 DILUPBiCG: Solving for H2O, Initial residual = 1, Final residual = 5.16628e-07, No Iterations 22 DILUPBiCG: Solving for CH4, Initial residual = 1, Final residual = 8.61173e-07, No Iterations 22 DILUPBiCG: Solving for CO2, Initial residual = 1, Final residual = 9.77546e-07, No Iterations 22 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 in "/lib/x86_64-linux-gnu/libm.so.6" #4 Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::pow(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 parserPatch::PatchValueExpressionParser::parse() in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #7 Foam::PatchValueExpressionDriver::parseInternal(int) in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #8 Foam::CommonValueExpressionDriver::parse(std::string const&, Foam::word const&) in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #9 Foam::CommonValueExpressionDriver::evaluateVariable(Foam::word const&, Foam::string const&) in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #10 Foam::CommonValueExpressionDriver::addVariables(Foam::string const&, bool) in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #11 Foam::CommonValueExpressionDriver::addVariables(Foam::List<Foam::string> const&, bool) in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #12 Foam::CommonValueExpressionDriver::clearVariables() in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so" #13 Foam::groovyBCFvPatchField<double>::updateCoeffs() in "/home/martin/OpenFOAM/martin-2.2.2/platforms/linux64GccDPOpt/lib/libgroovyBC.so" #14 Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #15 Foam::mixedEnergyFvPatchScalarField::updateCoeffs() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so" #16 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/reactingFoam" #17 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/reactingFoam" #18 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/reactingFoam" #19 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #20 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/reactingFoam" Gleitkomma-Ausnahme (Speicherabzug geschrieben) Best regards martin |
calculation of thermal conductivity in reactingFoam | sto16 | OpenFOAM Running, Solving & CFD | 11 | April 25, 2017 00:46 |
reactingFoam crashing | rishibigghe | OpenFOAM Running, Solving & CFD | 0 | June 14, 2011 18:50 |
Constant Volume Combustion with reactingFoam | Alish1984 | OpenFOAM Running, Solving & CFD | 2 | May 8, 2011 09:51 |
reactingFoam wedge handling wrong U | dhondupant | OpenFOAM Bugs | 1 | December 9, 2010 08:34 |
reactingFoam - turbulent reacting flow | hamburgFoam | OpenFOAM | 0 | December 7, 2009 13:57 |
