interFoam in parallel
Old   December 9, 2013, 06:09
Post interFoam in parallel
Reza
gooya_kabir is on a distinguished road
Hi FOAMers,
I'm working on interFoam in parallel. After many time step, it crashes and the following message appear:
[CODE][3] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[3] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 at ??:?
[3] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) at ??:?
[1] #4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) at ??:?
[3] #4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) at ??:?
[1] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) at ??:?
[3] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) at ??:?
[3] #6 at ??:?
[1] #6
[1] at ??:?
[1] #7 __libc_start_main[3] at ??:?
[3] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #8
[3] #8 [1] at ??:?
[pcubed1:08538] *** Process received signal ***
[pcubed1:08538] Signal: Floating point exception (8)
[pcubed1:08538] Signal code: (-6)
[pcubed1:08538] Failing at address: 0x3e90000215a
[pcubed1:08538] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7fec59217ff0]
[pcubed1:08538] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7fec59217f77]
[pcubed1:08538] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7fec59217ff0]
[pcubed1:08538] [ 3] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES7limiterINS_17geo metricOneFieldENS_9zeroFieldES3_EEvRNS_5FieldIdEER KT_RKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7vo lMeshEEERKNSA_IdNS_13fvsPatchFieldENS_11surfaceMes hEEESK_RKT0_RKT1_ddi+0xe0f) [0x7fec5bef8e5f]
[pcubed1:08538] [ 4] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES5limitINS_17geome tricOneFieldENS_9zeroFieldES3_EEvRKT_RKNS_14Geomet ricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS7_Id NS_13fvsPatchFieldENS_11surfaceMeshEEERSF_RKT0_RKT 1_ddib+0x205) [0x7fec5bef9bf5]
[pcubed1:08538] [ 5] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES13explicitSolveER NS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMesh EEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEER S8_dd+0x7d) [0x7fec5bee94bd]
[pcubed1:08538] [ 6] interFoam() [0x42725e]
[pcubed1:08538] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fec59202de5]
[pcubed1:08538] [ 8] interFoam() [0x42ae1a]
[pcubed1:08538] *** End of error message ***
[3] at ??:?
[pcubed1:08540] *** Process received signal ***
[pcubed1:08540] Signal: Floating point exception (8)
[pcubed1:08540] Signal code: (-6)
[pcubed1:08540] Failing at address: 0x3e90000215c
[pcubed1:08540] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7f6f9870fff0]
[pcubed1:08540] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x37) [0x7f6f9870ff77]
[pcubed1:08540] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36ff0) [0x7f6f9870fff0]
[pcubed1:08540] [ 3] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES7limiterINS_17geo metricOneFieldENS_9zeroFieldES3_EEvRNS_5FieldIdEER KT_RKNS_14GeometricFieldIdNS_12fvPatchFieldENS_7vo lMeshEEERKNSA_IdNS_13fvsPatchFieldENS_11surfaceMes hEEESK_RKT0_RKT1_ddi+0xe0f) [0x7f6f9b3f0e5f]
[pcubed1:08540] [ 4] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES5limitINS_17geome tricOneFieldENS_9zeroFieldES3_EEvRKT_RKNS_14Geomet ricFieldIdNS_12fvPatchFieldENS_7volMeshEEERKNS7_Id NS_13fvsPatchFieldENS_11surfaceMeshEEERSF_RKT0_RKT 1_ddib+0x205) [0x7f6f9b3f1bf5]
[pcubed1:08540] [ 5] /home/gooya/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam5MULES13explicitSolveER NS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMesh EEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEER S8_dd+0x7d) [0x7f6f9b3e14bd]
[pcubed1:08540] [ 6] interFoam() [0x42725e]
[pcubed1:08540] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f6f986fade5]
[pcubed1:08540] [ 8] interFoam() [0x42ae1a]
[pcubed1:08540] *** End of error message ***
mpirun noticed that process rank 1 with PID 8538 on node pcubed1 exited on signal 8 (Floating point exception)./CODE]
it is because mesh is not fine enough or because of solver?
Thank you for your comments and help.
gooya_kabir is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
interFoam parallel idefix OpenFOAM Pre-Processing 7 October 23, 2013 03:35
Interfoam blows on parallel run danvica OpenFOAM Running, Solving & CFD 16 December 22, 2012 03:09
interFoam (OF 1.7.1) in parallel ..need help farhagim OpenFOAM 4 July 26, 2012 17:42
InterFoam in parallel sara OpenFOAM Running, Solving & CFD 3 April 19, 2011 06:05
