December 8, 2013, 01:50 |
conjugate heat transfer: turn off turbulence
Sergey
Rep Power: 12 |
Hello!
The solver chtMultiRegionSimpleFoam for conjugate heat transfer is for compressible and turbulent flow. Is it possible to turn off turbulence and compressibility or is there another cht solver which is for incompressible laminar flow? I'm new to Open FOAM and CFD and would like to start from a simpler problem and see the effect of compressibility and turbulence. Thanks! |
December 10, 2013, 07:28 |
Michael
Rep Power: 14 |
chtMultiRegionSimpleFoam is developed for compressible flows. It is not possible to simply switch OF solvers from compressible to incompressible. That's why there are seperate solvers for compressible and incompressible flows.
Turbulence is switched off in cht* solvers if you choose turbulenceType laminar. Most cht tutorials in OF use laminar flow. |
December 10, 2013, 12:35 |
Sergey
Rep Power: 12 |
Michael, thank you for your reply.
Is there incompressible solver for conjugate heat transfer? |
December 13, 2013, 17:13 |
Sergey
Rep Power: 12 |
I'm confused. The chtMultiRegionFoam is compressible solver. But in the tutorial example chtMultiRegionLiquidHeater the water density is fixed.
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 07:33 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Conjugate heat transfer models | Alex | Phoenics | 8 | April 6, 2009 16:58 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
conjugate heat transfer | san | CFX | 9 | September 15, 2006 01:45 |
