Uniform inlet particle distribution without position file
Old   December 5, 2013, 18:24
Default Uniform inlet particle distribution without position file
India
mayank.dce2k7 is on a distinguished road
Hi Foamers,
I want to inject about 1000,000 particles at the inlet patch for my OpenFOAM particle solver case. Now it is not possible to generate position file to specify position for each of them....PatchInjection model does not ensure uniform particle distribution(surface density). Is there any other alternative method to ensure uniform(surface density) particle distribution without a position file?
Also, I want all particles to be injected at once at SOI just as in ManualInjection model.
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
