December 3, 2013, 02:49 |
dsmcFOAM output
sandy
Rep Power: 13 |
Hello ppl,
I solved a simple problem using dsmcFOAM solver. Now i need to extract the data out of it. I used the dsmcFieldsCalc to obtain the Pressure temperature and velocities. Now There was a folder named /Post processing Within the post processing folder, i find a forces.dat file. What is this file? I dont understand anything from this file. Can I use that dat file to plot in matlab ?? Help me guys Thanks |
February 8, 2014, 00:12 |
reji
Rep Power: 15 |
Results can be obtained by running dsmcFieldCalc "OR" adding force functions in the controlDict file (as in wedge15Ma5 tutorial).
The macroscopic(temp/overallT, P,Umean etc.) results are ensemble averaged output. You can edit controlDict force function with with "resetOnOutput off;" for time averaging from initial time (0) "OR" set "resetOnOutput on;" to get for time averaging from a later time ( after a getting steady result). |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 13:08 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 09:39 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
