pimpleDyMFoam solid body rotation restart issue |
benoit paillard
Rep Power: 16 ![]() |
Hi Everyone,
I'm having an issue with a case for which restarts behave strangely. The case is here. https://db.tt/EOi1wRN3 It is a 2D VAWT. The simulation runs fine and gives appropriate results compared with experimental data. However, whenever I stop and restart this case, I get weird velocity oscillations in the rotating domain and at the AMI, and a big pressure rise just at the restart. Then everything is smoothed out thanks to diffusion... Any help would be greatly appreciated. Last edited by bennn; November 29, 2013 at 08:27. |
[DesignModeler] Question about converting surface body to solid body in DesignModeler | lnk | ANSYS Meshing & Geometry | 2 | November 24, 2013 00:02 |
Detect a solid as a Surface Body | Atefeh | ANSYS | 2 | December 19, 2012 03:38 |
rigid body rotation through an axis not passing through centre of gravity | ranjith | CFX | 5 | November 22, 2012 16:08 |
[ANSYS Meshing] Solid to Solid Interface Issue | cvetkovc | ANSYS Meshing & Geometry | 1 | October 22, 2012 17:09 |
Rigid body rotation NOT through the CG? | Joe | FLUENT | 6 | May 28, 2010 11:03 |
