dam break
Old   November 24, 2013, 18:17
Default dam break
Alexander
Svensson is on a distinguished road
Send a message via Skype™ to Svensson
Hello everybody. I am trying to simulate an experiment, which I've conducted earlier. And I have faced with some difficulties. An Experimental apparatus is a tank filled by liquid (there is no free surface) . An internal volume of the tank is fluid-tightly devided into two equal parts by internal thin baffle. One of them is filled by liquid with dissolved NaCl (heavy liquid) and another one is filled by pure water (light liquid). In the time t=0 baffle begins moving and is completely removed from the tank by the time t=2.8 s. Below is experimental scheme
I don't know how to simulate thin removing baffle. And I would be glad to get advice.
Best Regards, Alexander.
Svensson is offline   Reply With Quote
Old   November 25, 2013, 05:14
Thomas Vossel
ThomasV is on a distinguished road
Hi!
Did you have a look at the incompressible -> pimpleDyMFoam -> movingCone case?
ThomasV is offline   Reply With Quote
Old   November 25, 2013, 06:18
Alexander
Originally Posted by ThomasV View Post
Hi!
Yes. I've seen it. I tried to use this technics, but I couldnt solve problems caused of a mesh movement. While baffle was moving, cells located near the top wall became more and more warped with high aspect ratio. I tried to set an dynamicMeshDict to add cell layers on the top wall and to remove ones on the lower wall, but I didn't have success in it. I'll add some pics of the mesh in the evening.
Old   November 25, 2013, 15:30
Alexander
here you are (it's a simplified model):
My dynamicMeshDict:
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver          velocityComponentLaplacian;
velocityComponentLaplacianCoeffs
    component       z;
    diffusivity     directional ( 200 0 100);
and pointMotionUz:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    movingWall
        type            uniformFixedValue;
        uniformValue    constant 100;
    slipWalls
        type            slip;
    fixedWalls
        uniformValue    constant 0;
    frontAndBack
        type            empty;
buffle, dam break, removable buffle, thin baffle
compressible dam break simulation smsanth OpenFOAM Running, Solving & CFD 0 September 2, 2013 03:51
3D dam break modeling(earthen dam) yasharif FLUENT 0 December 11, 2011 02:25
Boundary Condition in dam break atabak756 FLUENT 2 June 3, 2011 03:51
3D dam break flow problem woochang CFX 1 February 18, 2010 17:47
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
