conjugate heat transfer in OpenFOAM
Like Tree28Likes
Old   January 24, 2015, 15:12
Retired Super Moderator
Bruno Santos
Greetings Vasava,
Many thanks for sharing your solution!
I have to say that it's interesting to see a situation where a partial transient solution is useful for initializing a steady-state simulation.
The explanation for this should be easy enough: the transient simulation accounts for the full dynamics of the simulation, while the steady-state does essentially an averaged solution.
This is similar to the situations where increasing the mesh resolution makes it harder to converge a simulation, precisely because the additional resolution reveals new physical details that give a new solution to the simulation... which may be incomplete, due to an incomplete mesh resolution.
Anyway, beyond the existentialist point of view of temporal-spacial discretization, the problem you're seeing could related to a similar situation, for example, imagine this:
  1. You have a box that has a heat-flux inlet and a temperature outlet.
  2. As a steady-state simulation, the simulation will never converge and could possibly heat up or freeze up endlessly.
  3. While the transient simulation will not heat up or freeze up.
  4. The reason for this is exactly because of the real time vs averaging situation: averaging the heat exchange effect in some cases will not result in a real steady-state situation.
In your case, you got an extreme situation: the heating as a steady-state simulation resulted in an accelerated heat-up of a particular region, while the transient simulation was able to dissolve the heat properly over time.
Best regards,
Bruno
vasava and elham usefi like this.
Old   January 26, 2015, 02:20
Paritosh Vasava
vasava will become famous soon enough
Thank you Bruno Santos for the explanation!! It nice to begin the week by learning something new. I still consider my self a beginner at both: the CFD and the openFoam. Its nice to learn and discover new things everyday!!
One more thing to add: During my initial experiments I used to initialize the region where the hot fluid is flowing with maximum temperature and the region where the cold fluid is flowing with minimum temperature. This would also cause a very high temperature gradients at the very thin pipe walls (also divergence). But initializing all the domains with minimum temperature and allowing the simulation take its own course gave me quite reasonable solutions.
wyldckat likes this.
vasava is offline   Reply With Quote
Old   January 26, 2015, 02:45
T. Chourushi
Tushar@cfd is on a distinguished road
Thanks for briefing your views. I totally agree with you, when you start your simulation with large difference/error (as hot/cold fluid in your case) it is more likely to have stability issues. It's always better to follow your approach for stable solutions.
Best Regards!
Tushar@cfd is offline   Reply With Quote
Old   August 16, 2015, 10:46
Default chtMultiRegionFoam
  #64
dafe
dafe is on a distinguished road
Hi everyone, I am new to open foam and trying to model heat transfer in a closed circuit pipe/tube(rectangular shape for simplicity). In my blockMeshDict when specifying boundary; for the leftwall for example, do i just take the extreme outer face or do i have to specify both faces on the left side (inside and outside). Most tutorials i have seen are basically cavity types which have only one wall to the left. Thanks
dafe is offline   Reply With Quote
Old   August 16, 2015, 14:35
Bruno Santos
Quick answer: http://www.cfd-online.com/Forums/ope...egionfoam.html
Old   August 16, 2015, 15:34
dafe
thanks for the link, will check it out and get back to you.
Old   January 22, 2016, 18:15
laurentL
laurent98 is on a distinguished road
@Vasava
thanks so much for this idea, i'm facing this problem for weeks, i must run before chtMultiRegionFoam .? ( I’m also a beginner, build a solver look like a hard job to me...)
thank you very much.
laurent98 is offline   Reply With Quote
Old   June 24, 2016, 11:50
Bruno
MBttR is on a distinguished road
Hi!
In the end I want to simulate a cylinder generating heat in a flow of air with some other blocking geometries as well, but seeing how the rule is to start of simple and increase complexity I started with the planeWall2D tutorial by Bruno Santos, accompanied by the report by Maaike van der Tempel.
I thought I understood everything so went to my next step of complexity; modelling a 3D cylinder of 350K suspended in a volume of air of 300K. This however crashed after a couple of iterations (not the first one) due to temperatures going very high (100,000K), then very low/negative. At one point I could get it such that the temperature fluctuated for tens of thousands of Kelvin and then settled around more reasonable 345K values. This however seemed like complete bogus to me so I went back a step on the complexity ladder.
I returned to the planeWall2D case, this time turning it into a 2D block suspended in the air. However, my solution still diverges to a negative temperature after many iterations making the simulaiton crash, as can be seen in the ending of my log.chtMultiRegionSimpleFoam. I will post my code after the error.
Solving for fluid region bottomAir
DILUPBiCG:  Solving for Ux, Initial residual = 0.373465, Final residual = 0.0008348504, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.3983659, Final residual = 0.002457276, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.03343168, Final residual = 7.176597e-05, No Iterations 1
Min/max T:296.7828 345.5452
GAMG:  Solving for p_rgh, Initial residual = 0.2517964, Final residual = 0.001801136, No Iterations 4
time step continuity errors : sum local = 1.80743, global = 0.1183804, cumulative = 0.3588659
Min/max rho:0.8133568 2
Solving for solid region wall
DICPCG:  Solving for h, Initial residual = 0.03221371, Final residual = 0.0003819145, No Iterations 1
Min/max T:min(T) [0 0 0 1 0 0 0] 345.3996 max(T) [0 0 0 1 0 0 0] 345.6923
ExecutionTime = 90.23 s  ClockTime = 90 s
Time = 1313
DILUPBiCG:  Solving for Ux, Initial residual = 0.1843478, Final residual = 0.001331729, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.3706879, Final residual = 0.002551714, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.02562959, Final residual = 0.0002373, No Iterations 1
Min/max T:297.6073 345.5416
GAMG:  Solving for p_rgh, Initial residual = 0.2469737, Final residual = 0.002262424, No Iterations 4
time step continuity errors : sum local = 1.180225, global = 0.8575721, cumulative = 1.216438
Min/max rho:0.2 1.670909
DICPCG:  Solving for h, Initial residual = 0.03223895, Final residual = 0.0003933997, No Iterations 1
Min/max T:min(T) [0 0 0 1 0 0 0] 345.3962 max(T) [0 0 0 1 0 0 0] 345.6887
ExecutionTime = 90.3 s  ClockTime = 90 s
Time = 1314
DILUPBiCG:  Solving for Ux, Initial residual = 0.5954829, Final residual = 0.0007776412, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.5604225, Final residual = 0.002729626, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.08661401, Final residual = 0.0003479413, No Iterations 1
Min/max T:-1155.061 345.5381
GAMG:  Solving for p_rgh, Initial residual = 0.4870689, Final residual = 0.001921832, No Iterations 4
time step continuity errors : sum local = 2.404536, global = -0.1866434, cumulative = 1.029795
Min/max rho:0.2 2
DICPCG:  Solving for h, Initial residual = 0.050871, Final residual = 0.0007805152, No Iterations 2
Min/max T:min(T) [0 0 0 1 0 0 0] 345.0073 max(T) [0 0 0 1 0 0 0] 345.6852
ExecutionTime = 90.37 s  ClockTime = 90 s
Time = 1315
DILUPBiCG:  Solving for Ux, Initial residual = 0.3712775, Final residual = 0.001556036, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.5173233, Final residual = 0.001700514, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.1986274, Final residual = 7.361579e-05, No Iterations 1
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
    From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
    in file /home/bruno/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#3  Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
#4  ? at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? at ??:?
Aborted (core dumped)
Now for the code; To do this I kept blockMesh the same:
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (1 0 0)
    (1 1 0)
    (0 1 0)
    (0 0 0.1)
    (1 0 0.1)
    (1 1 0.1)
    (0 1 0.1)
blocks
    hex (0 1 2 3 4 5 6 7) (100 100 1) simpleGrading (1 1 1)
edges
boundary
    topAir_top
        type patch;
        faces
            (3 7 6 2)
    bottomAir_bottom
        type patch;
        faces
            (1 5 4 0)
    leftLet
        type patch;
        faces
            (0 4 7 3)
    rightLet
        type patch;
        faces
            (2 6 5 1)
    frontAndBack
        type empty;
        faces
            (0 3 2 1)
            (4 5 6 7)
mergePatchPairs
and changed topoSet to:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
    // wall
        name    wall;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (0.4 0.4 0 )(0.6 0.6 0.1);
        name    wall;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set wall;
    // bottomAir
        name    bottomAir;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (0 0 0 )(1 1 0.1);
        name    bottomAir;
        type    cellSet;
        action  delete;
        source  boxToCell;
        sourceInfo
        name    bottomAir;
        type    cellZoneSet;
        action  new;
        sourceInfo
            set bottomAir;
As you can see I deleted topAir from the default case and kept the name bottomAir to keep as much things alike as possible. I then changed the bottomAir changeDictionaryDict to:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      changeDictionaryDict;
dictionaryReplacement
    boundary
        bottomAir_bottom
            type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
    U
        internalField   uniform (0.1 0 0);
        boundaryField
            leftLet
                type            fixedValue;
                value           uniform ( 0.1 0 0 );
            rightLet
                type            inletOutlet;
                inletValue      uniform ( 0 0 0 );
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            "bottomAir_to_.*"
                type            fixedValue;
                value           uniform (0 0 0);
    T
        internalField   uniform 300;
        boundaryField
            leftLet
                type            fixedValue;
                value           uniform 300;
            rightLet
                type            zeroGradient;
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            "bottomAir_to_.*"
                type            compressible::turbulentTemperatureCoupledBaffleMixed;
                Tnbr            T;
                kappa           fluidThermo;
                kappaName       none;
                value           uniform 300;
    epsilon
        internalField   uniform 0.01;
        boundaryField
            leftLet
                type            inletOutlet;
                inletValue      uniform 0.01;
                value           uniform 0.01;
            rightLet
                type            fixedValue;
                value           uniform 0.01;
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            "bottomAir_to_.*"
                type            compressible::epsilonWallFunction;
                value           uniform 0.01;
    k
        internalField   uniform 0.1;
        boundaryField
            leftLet
                type            inletOutlet;
                inletValue      uniform 0.1;
                value           uniform 0.1;
            rightLet
                type            fixedValue;
                value           uniform 0.1;
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            "bottomAir_to_.*"
                type            compressible::kqRWallFunction;
                value           uniform 0.1;
    p_rgh
        internalField   uniform 1e5;
        boundaryField
                type            fixedFluxPressure;
                value           uniform 1e5;
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            leftLet
                type            fixedValue;
                value           uniform 1e5;
            frontAndBack
                type            empty;
    p
        boundaryField
                type            calculated;
                value           uniform 1e5;
            bottomAir_bottom
                type            symmetryPlane;
	topAir_top
            type            symmetryPlane;
            leftLet
                type            calculated;
                value           uniform 1e5;
            frontAndBack
                type            empty;
and the wall changeDictionaryDict to:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    T
        internalField   uniform 350;
        boundaryField
            ".*Let"
                type            zeroGradient;
                value           uniform 300;
            "wall_to_.*"
                Tnbr            T;
                kappa           solidThermo;
                kappaName       none;
                value           uniform 300;
I have changed the relaxationFactor h for airBottom from 0.7 to 0.3, but that maybe gave me a couple more iterations before crashing as well. I know this must be something really simple but I am at a complete loss. I don't see what can be wrong about my boundary conditions, why they should be any different than the standard planeWall2D case. Maybe it is something in fvSchemes or fvSolution but again, I'm not sure why that would be. I decreased timesteps to no avail.
For the sake of completeness I'm attaching the case here as well.
Can anyone shed some light on this? Many thanks! And for those on their way to the workshop in Portugal, have fun.
Greetings,
Bruno
MBttR is offline   Reply With Quote
Old   June 27, 2016, 01:04
Vishesh
visheshkapoor06 is on a distinguished road
Hi Bruno,
I am facing the same problem but my velocity is diverging in the 1st iteration and the temperature in the 2nd.
Can you please tell, how did you corrected it such that the iterations ran and settled after a while?
Also, I am using OpenFOAM 3.0.1, should i try and run the case using openFOAM 2.4.0?
Thank you
Regards
Vishesh
visheshkapoor06 is offline   Reply With Quote
Old   July 28, 2016, 12:39
Default Porting PlaneWall 2D for OF1606+
  #70
Jaydeep
jaydeep is on a distinguished road
Hello everyone,
I have been trying to port the classic PlaneWall 2D case for the latest OF release. I am attaching the zip for all files. The case runs well, but in the end it throws a ton of errors on ParaView and results are in my opinion unrealistic.
Can somebody take a look at it and please let me know what all could be the probable causes ?
Thanks!
P.S. I use OF+ on windows, use native ParaView. Once the simulation is finished, you can open foam.foam file in PV for postprocessing.
jaydeep is offline   Reply With Quote
Old   July 28, 2016, 16:53
Default Initial condition issues in PV
  #71
Jaydeep
I guess I could narrow down the errors in ParaView to initial condition. After splitmesh the newly created boundaries do not appear explicitly in 0. And thus ParaView on windows fails to recognize .* . Now I am not sure whether this has to do with the OF for windows, or is it a general problem. Can someone take a look at it?
P.S. Still the results look unreasonable
Old   September 18, 2016, 12:23
sitajeje is on a distinguished road
Dear Bruno,
thank you very much first of all for your planeWall2D. I downloaded your case files and run it. But the resultant planeWall2D.OpenFOAM file is empty. The Paraview exit automatically when I press on "apply" button to load the data. My OpenFOAM is V4.0.
I would appreciate greatly if you can help me on this, although it is a 3 year old post.
Best regards,
Hai
sitajeje is offline   Reply With Quote
Old   September 18, 2016, 16:50
Bruno Santos
Quick answers: First of all, sorry to everyone, but:
  1. I haven't had enough free time to look into your questions and I won't be able to answer to them all on this post right now.
  2. I can't find it right now, but I know I wrote a post... last year, I think... in which I stated that the tutorial was not working properly as of OpenFOAM 2.3. This situation still stands, as I haven't managed to find enough time to study things properly.
The best I can suggest right now is suggest what I suggested to another forum member a few days ago:
Originally Posted by wyldckat View Post
so the best I can do is suggest that you study the course presentation and cases that are provided here: http://www.openfoamworkshop.org/courses - look for the presentation "Learning how to use free surface flows in OpenFOAM 3.0" and click on the download link to the right of the entry "Training Material".
The free surface flows are also using the same kind of pressure management as in the chtMultiRegion*Foam solvers.
Now, to answer in detail to a few questions:
Yes, the internal reader in ParaView does not support all boundary conditions that OpenFOAM supports at the moment. Therefore, ParaView will complain when it doesn't understand a boundary condition
It's as I indicated at the start of this post that you're reading.
Yes, the file is meant to be empty, it's just sort-of a tag for ParaView to know which folder to use.
And it looks like you did not properly ready the wiki page. This is explained here: http://openfoamwiki.net/index.php/Ge...ost-Processing
Old   September 19, 2016, 15:42
Dear Bruno,
thank you very much for your prompt reply! I am a beginner for OpenFOAM and can easily make stupid mistakes.
I wonder whether I have done anything wrong. After I executed Allrun, I didn't get
planeWall2D{bottomAir}.OpenFOAM planeWall2D{topAir}.OpenFOAM planeWall2D{wall}.OpenFOAM
but only planeWallD.OpenFOAM and planeWallD.blockMesh. The other 7 files begin with log..
I use Ubundu 14.04, and OpenFOAM 4.0. I would appreciate greatly if you can give me a guide.
Thank you very much in advance!
Have a nice evening!
Sitajeje
Old   September 20, 2016, 08:07
Paritosh Vasava
I see that you are using ideal gas for fluid. Also, there is negative temperature (around -500 K and I havent investigated the cause of the negative temperature) and it is causing the simulation to diverge.
If you aim is to merely simulate conjugate heat transfer, I recommend you to switch to normal air properties.
Old   September 20, 2016, 08:36
Paritosh Vasava
You dont need separate files for separate regions to view results, the file planeWallD.OpenFOAM should be enough.
Old   September 21, 2016, 12:13
Alex
zfaraday will become famous soon enough
I think you are wrong Paritosh, actually you need those files in order to be able to see the results in each region, otherwise you can't watch the results!
In order to create them, the command to be executed is
paraFoam -touchAll
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   September 21, 2016, 14:56
Dear Alex and Paritosh,
thank you very much for your help! I wonder whether you have the planeWall2D case file which you have run through? I would appreciate if you would share it with me. I still cannot get the planeWall2D{bottomAir}.OpenFOAM, planeWall2D{topAir}.OpenFOAM and planeWall2D{wall}.OpenFOAM files.
All the best
sitajeje
Old   September 22, 2016, 02:45
Paritosh Vasava
paraFoam -touchAll
I use,
paraFoam -builtin
Which creates only one file, case.foam. Works just fine. Just another way.
Old   September 24, 2016, 13:03
Thank you very much Paritosh! The command "paraFoam -touchAll" exists in the "Allrun" file. After execution, the "planeWall2D.OpenFOAM" is empty. I don't have folders of "bottomAir", "topAir" or "wall" in the "0" folder.
I ran through the tutorial "multiRegionHeater", created files such as "multiRegionHeater{bottomWater}.OpenFOAM" and also folders such as "bottomWater" in the "0" folder. However all the "*.OpenFOAM" files were empty. The command "paraFoam -touchAll" also exists in the "Allrun" file. In paraView I can only find the blockMesh, nothing more. The terminal didn't report an error, and seems to run through all the commands in the "Allrun" file.
I am a beginner for OpenFOAM. I wonder whether my installation was incomplete. I could run the tutorial case "cavity" successfully.
Thank you very much for your help in advance!
cht, solid-fluid interface
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
openfoam for heat transfer kirankarki OpenFOAM Running, Solving & CFD 29 February 12, 2015 19:46
Conjugate Heat transfer in CFX ksp1717 CFX 11 December 10, 2010 23:07
Conjugate Heat Transfer of Motorized EGR enr_venkat CFX 1 October 12, 2010 19:17
best mesh generator for conjugate heat transfer? phsieh2005 Main CFD Forum 1 June 1, 2007 18:35
