cyclic boundary error: "Coupled patches with transformations not supported"
Old   November 20, 2013, 04:15
Default cyclic boundary error: "Coupled patches with transformations not supported"
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Dear all,
I am trying to get a turbulent pipe profile using the cyclic boundary condition on a short piece of pipe.
I use the settings of the "channel395" tutorial and I get the error message:
--> FOAM FATAL ERROR:
Coupled patches with transformations not supported.
Problematic patch IN
    From function extendedCellToCellStencil::extendedCellToCellStencil(const polyMesh&)
    in file fvMesh/extendedStencil/cellToCell/extendedCellToCellStencil.C at line 50.
FOAM exiting
I don't understand the message. Can someone help me?
BTW: this is an ICEM mesh, that I converted via "Fluent3dMeshtoFoam". I did not set any periodic stuff in ICEM.
boundary file:
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
3
    IN
        type            cyclic;
    inGroups        1(cyclic);
        nFaces          7605;
    startFace       2243358;
    matchTolerance  0.0001;
    neighbourPatch  OUT;
    OUT
        type            cyclic;
    inGroups        1(cyclic);
        nFaces          7605;
        startFace       2250963;
    neighbourPatch  IN;
    PIPE_WALL
        type            wall;
        nFaces          15444;
        startFace       2258568;
fvOptions:
|  \\    /   O peration     | Version:  2.2.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
momentumSource
    type            pressureGradientExplicitSource;
    active          on;            //on/off switch
    selectionMode   all;       //cellSet // points //cellZone
    pressureGradientExplicitSourceCoeffs
        fieldNames  (U);
        Ubar        ( 0 0 10 );
All boundary files looks like this (U):
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 10);
boundaryField
    IN
    type cyclic;
    OUT
    type cyclic;
    PIPE_WALL
        type            fixedValue;
        value           uniform (0 0 0);
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   November 20, 2013, 05:23
Philipp
Ok, I got it: after trying to understand what the CellToCell... files do, I changed the gradient scheme from
"grad(U) faceLimited pointCellsLeastSquares 1;"
to Gauss linear. Now it works.
So no edgeCellLeastSquares with cyclic boundary conditions? I also see this in the chanell395 tutorial.
Old   May 9, 2016, 13:51
loreasr is on a distinguished road
I'm experiencing the same problem with my case. I have a cyclic BC and I would like to use The CubicUpwindFit scheme but I get the same error. Any idea of how make it works?
Best wishes
Lorenzo
loreasr is offline   Reply With Quote
Old   July 22, 2016, 13:14
Yousef
ykanani is on a distinguished road
Best wishes
Lorenzo
Hello Lorenzo,
I am trying to do the same thing. Did you find any solution?
I need to try higher order upwind scheme in my simulations and it seems this is the only available option in the OpenFOAM which unfortunately does not support the cyclic boundary conditions.
I appropriate if you let me know if you already figured this out.
Thanks,
Yousef
ykanani is offline   Reply With Quote
interFoam and cyclic boundary condition issue General_Gee OpenFOAM Running, Solving & CFD 17 October 8, 2018 10:33
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Adaptive Mesh Refinement and Cyclic Boundary Conditions adona058 OpenFOAM Running, Solving & CFD 6 October 23, 2009 10:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
