November 14, 2013, 16:21 |
chtMultiRegionSimpleFoam div schemes
erik gustafsson
Rep Power: 12 |
Hello
I have problem with my epsilon in my simulation. I have considerd my boundary conditions and they seems correct. Another suggestion i've found here on the forum is the switch divergence scheme. For all tutorials related to chtMultiRegionSimpleFoam the bounded Gauss upwind is used and when i try to switch scheme openfoam complains about this. Anyone have an suggestion whcih schemes that im allowed to use? |
November 14, 2013, 16:55 |
David
Rep Power: 14 |
I tell you some thoughts (i have no experience with that solver though):
- What kind of problem do you have whit epsilon? Residuals blowing up? - If so, look at your case before that happened and look for mesh problems - Also if you are trying to set an upwind condition you may have to specify the flux variable so try to type upwind phi instead of upwind |
November 14, 2013, 17:30 |
#3 | |
erik gustafsson
Rep Power: 12 |
simpleFoam: case only converges with most div schemes set to upwind | buffi | OpenFOAM Running, Solving & CFD | 7 | November 11, 2013 07:54 |
Numerical schemes for grad and div | Tobi | OpenFOAM | 6 | March 11, 2013 21:24 |
Need modification for MUSLE or MC schemes | liuhuafei | OpenFOAM Bugs | 3 | June 13, 2010 02:38 |
time stepping schemes for compressible DNS/LES | shyamdsundar | Main CFD Forum | 0 | January 14, 2010 23:15 |
Higher-order bounded convection schemes for pure advection with discontinuity | Anthony | Main CFD Forum | 3 | June 13, 1999 02:36 |
