November 7, 2013, 13:57 |
LES gust factors
Marcus Letzel
Rep Power: 14 |
Dear FOAMers,
consider the task of calculating atmospheric LES gust factors near an obstacle, where the gust factor G is locally and instantaneously defined as the ratio of vg_local and vg_ref. Both vg_local and vg_ref are scalars, only the velocity magnitude is considered. The timestep of the LES is about 0.1 s.
I invite you to share your experience in how to approach this task. I hope to do as many steps as possible on-the-fly inside OpenFOAM. Some preliminary thoughts:
Best regards, Marcus |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 15:52 |
Beginning to work in LES - Suggestions needed | atmcfd | Main CFD Forum | 5 | July 20, 2012 23:16 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 12:35 |
Under relaxation factors for LES | Dinesh | Main CFD Forum | 0 | March 26, 2006 07:25 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 10:58 |
