Set up for High performance cluster
Old   November 5, 2013, 17:06
Default Set up for High performance cluster
c0sk is on a distinguished road
Hi! I have 2 question regarding the flow past a sphere I am simulating in 3D, the sphere Diameter is 0.1m, nu=1.5*10-3 and is in a free stream U (4.5 0.1 0.1). With this set up (Re=300) will I be able to see Karman vortices using icoFoam?
Furthermore, to run this case I have access to a a ~6000 core high bandwidth, low latency Linux cluster of 2.66 GHz Intel "Westmere" cores based on 2 sockets and 12 cores per node. I have now idea what the optimal decomposePardict would be, I went through dozen of posts and manuals but still cant figure it out. Assuming I would use 6 nodes for a total of 12 sockets and 72 cores, what would I specify in the dict, which is the important value? 12 or 72?
Thanks
Regards
Andrea
c0sk is offline   Reply With Quote
Old   January 30, 2014, 18:09
Joachim Herb
jherb is on a distinguished road
You probably found this out yourself: If you want to use 72 core you have to split your fluid domain into 72 partitions (and run 72 mpi processes)
jherb is offline   Reply With Quote
Old   January 31, 2014, 00:33
Josh
joshm is on a distinguished road
In regards to the first part of the second question, I think it would be highly dependent on the specific hardware. Because your calculations are iterating thousands of times to get your solution, small differences in the hardware's ability to perform a small task are greatly amplified. If you are going to be using the hardware for a long time, it's best to perform a benchmark test of your own.
joshm is offline   Reply With Quote
Urgent problem! Appreciate all you help!! 3D Centrifugal Pump set up problems! RR2 FLUENT 5 April 13, 2012 09:17
Parallel rerun in cluster Andy_bm OpenFOAM Running, Solving & CFD 4 November 27, 2011 08:16
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 05:31
OpenFOAM installation on SUSE92 problems derath OpenFOAM Installation 1 April 3, 2006 07:44
link to cluster performance study fourier Main CFD Forum 0 March 8, 2002 02:00
