buoyantSimpleFoam and watertank
Like Tree25Likes
Old   December 18, 2022, 09:15
Default p_rgh and non-uniform density
  #101
Fatih Tüzün
FatihT is on a distinguished road
I'm facing a similar problem with non-uniform density over a water tank with supercritical water. The density is in a range of 85 to 1012 kg/m³.
I did the initialization with codeStream. (see below)
If you calculate the density from the pressure difference at the very bottom,
(p-p_rgh)/(gh) density corresponds to the local density.
Is there a way to use domainIntegrate to integrate the density up to the current height?
Or something like: p_hyd += rho*g*(h-h[-1])
buoyantFoam/pEqn.H:
// For steady closed-volume compressible cases adjust the pressure level
// to obey overall mass continuity
if (adjustMass && !thermo.incompressible())
p += (initialMass - fvc::domainIntegrate(thermo.rho()))
/fvc::domainIntegrate(psi);
p_rgh = p - rho*gh - pRef;
p_rgh.correctBoundaryConditions();
FatihT is offline   Reply With Quote
