buoyantSimpleFoam and watertank
Like Tree25Likes
Old   January 14, 2014, 16:28
Bernhard
BernhardS is on a distinguished road
Unfortunately I do not get beyond 0.07 seconds before the pressure blows up. If have attached the new version with the modified Allrun script. Switching off the turbulence does not make any difference...
BernhardS is offline   Reply With Quote
Old   January 15, 2014, 12:32
Bernhard
I am able to run that case if I change the BCs for p_rgh for bottom and wall to buoyantPressure and the one for top to fixedValue. Additionally I use funkySetField to initialize p. I have to use a lot of outerCorrectors (~30) at the beginning and underrelaxation, especially for p_rgh.
The velocity profile at the wall, due to the heat loss, is not as distinctive as before with buoyantBoussinesqPimpleFoam (see post #36). While the velocity profile is well developed in the lower region (after 360 sec), there are some disturbances in upper region probably caused by the BC for the top face.
At least the temperature distribution is stable and quite uniform in radial direction (except at the outer wall with the heat flux) which was previously not the case.
Does anyone have an idea which BCs might be as well appropiate for a closed tank?
Even though the case is running with the current BCs, it is probably a wrong setup since there is still some velocity (see Fig. 2, UY) at the top face where it should actually be zero...
Old   January 15, 2014, 17:07
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi Bernhard,
I tryed several options.
- changing 0/ files
- changing initialization
- changing thermodynamicProperties (with air its working)
- test case with cht
- test case with buoyant
- test case with boussinesq
- testings with diverent meshes
- testings with several fvSolution options
- changing pEqn.H in buoyantPressure
- checking with laminar and turbulent flow characteristics
Summary:
- most simulations have a continuity problem (U_x,y,z) blow up and p_rgh too
- re-coarse the mesh did not solve the problem
- thermodynamics changing to perfectGas with air is working
- changing p_rgh (top) to fixedValue is working but the results are bad.
At the moment I am out of ideas - sorry.
Tobi is offline   Reply With Quote
Old   January 16, 2014, 05:13
Bernhard
Thanks for all your efforts, I also think that the thermophysical model is the problem. If I set the second coefficient for rho to zero the case is working...
Old   January 17, 2014, 08:18
Tobi's Avatar
Tobias Holzmann
Additionally you can set g to (0 0 0)^T - it should give the same possibilty to solve the case but you need gravitation.
Old   March 3, 2014, 16:00
nsf
Nicolas Edh
nsf is on a distinguished road
Originally Posted by jherb View Post
Add the following line to your thermophysicalProperties:
dpdt no;
see:
[/code]
Hi all,
I might have an explanation of why the solution diverges when the density is non-constant and dpdt is on. I am hoping for your comments.
By using icoPolynomial we are setting the fluid as incompressible, i.e. \rho(p,T) = \rho(T). So we have, by definition:
\frac{\partial\rho}{\partial p} = 0
Which is what icoPolynomial returns when the function psi is called. For an ideal gas \frac{1}{RT} is returned. The compressibility can be expanded to
\frac{\partial\rho}{\partial t} \frac{\partial t}{\partial p} = 0
or
\frac{\partial\rho}{\partial t}\left[ \frac{\partial p}{\partial t}\right]^{-1} =0
So if we have non constant density, \frac{\partial\rho}{\partial t} \ne 0 and hence \frac{\partial p}{\partial t} must diverge?
Perhaps we would need and compressiblePolynomial class where the compressibility can be set even though it's really small for water?
Any thoughts?
Cheers
Nicolas
nsf is offline   Reply With Quote
Old   October 31, 2014, 09:33
Ezequiel Fogliatto
efogliatto is on a distinguished road
Hi Bernhard,
I'm facing a similar problem when I try to use icoPolynomial in a closed cavity. Could you solve your case?
efogliatto is offline   Reply With Quote
Old   December 4, 2014, 04:59
MK.
MK
MK. is on a distinguished road
What kind of boundary conditions did you use? Could you be so nice and tell me which BC you used for the simulation with buoyantSimpleFoam, specially p and p_rgh. I am confused about these BC. I have changed the solver as recommended by Tom in the post.
Have a nice weekend,
MK.
MK. is offline   Reply With Quote
Old   December 26, 2014, 09:49
a
minaret is on a distinguished road
Originally Posted by Tobi View Post
Hi all,
now the pressure fields are the same (buoyantSimpleFoam and chtMultiRegionSimpleFoam) .
I had to change the schemes to get the same results
Now I am going to check if its working wit a bigger domain.
hi
I have continuity error with buoyantSimpleFoam
how did you change the schemes?
thanks
minaret is offline   Reply With Quote
Old   February 7, 2017, 10:48
Default BuoyantPimpleFoam crashes when using polynomial thermophysical properties
  #50
Antoine
antoine_hub is on a distinguished road
Hi everyone,
I am using OpenFOAM 4-1 and I would like to run the buoyantPimpleFoam tutorial "hotroom" with the polynomial properties. The problem is the same as many of you got earlier which is that the solver crashed after few iterations (here 1 ...) and which is the following:
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : buoyantPimpleFoam
Date : Feb 07 2017
Time : 14:27:43
Host : "workstation"
PID : 29230
Case : /home/antoine/OpenFOAM/antoine-4.1/run/heatTransfer/buoyantPimpleFoam/hotRoom
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport polynomial;
thermo hPolynomial;
energy sensibleEnthalpy;
equationOfState icoPolynomial;
specie specie;
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
Reading field p_rgh
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Radiation model not active: radiationProperties not found
Selecting radiationModel none
No finite volume options present
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 0.0012
Time = 0.0012
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.6982e-14, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 5.23806e-14, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 0.999992, Final residual = 0.00742046, No Iterations 8
time step continuity errors : sum local = 4.1936e-08, global = 8.41042e-10, cumulative = 8.41042e-10
DICPCG: Solving for p_rgh, Initial residual = 0.971329, Final residual = 1.36506, No Iterations 1001
time step continuity errors : sum local = 5.85951e-07, global = 8.41042e-10, cumulative = 1.68208e-09
DICPCG: Solving for p_rgh, Initial residual = 0.97777, Final residual = 0.00967648, No Iterations 83
time step continuity errors : sum local = 1.06797e-07, global = 8.41042e-10, cumulative = 2.52313e-09
DICPCG: Solving for p_rgh, Initial residual = 0.986932, Final residual = 8.90563e+07, No Iterations 1001
time step continuity errors : sum local = 9.63673, global = 8.41042e-10, cumulative = 3.36417e-09
ExecutionTime = 0.3 s ClockTime = 1 s
Courant Number mean: 9.24507 max: 26.4701
deltaT = 2.26671e-05
Time = 0.00122266707585703
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 0.0532814, Final residual = 8.28644e-08, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.046897, Final residual = 7.8823e-08, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.0402159, Final residual = 1.72421e-10, No Iterations 3
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 4.72054e-08, No Iterations 3
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded
From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hPolynomialThermo<Foam::icoPolynomial<Foam:: specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hPolynomialThermo<Foam ::icoPolynomial<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /home/antoine/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam:olynomialTransport<Foam:: species::thermo<Foam::hPolynomialThermo<Foam::icoP olynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > >::calculate() at ??:?
#3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam:olynomialTransport<Foam:: species::thermo<Foam::hPolynomialThermo<Foam::icoP olynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > >::correct() at ??:?
#4 ? at ??:?
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6 ? at ??:?
Aborted (core dumped)
I have followed the different advices given in this thread like:
*refining the mesh
*changing the pressure initialization in the solver or using funkySetFields to initialize the pressure
*modifying the relaxation factors in the fvSolution as well as increasing the number of inner and outer correctors
*using dpdt off/no
However, none of these solutions was solving my problem.
Has someone already had this problem before and solved it? Or do you have other any trick I could try to make it work?
Many thanks,
Antoine
antoine_hub is offline   Reply With Quote
Old   February 7, 2017, 11:01
Tobi's Avatar
Tobias Holzmann
Dear Antionio,
please start with dt = 1e-7. You first time step is too big and therefore the courant number explodes already: Courant Number mean: 9.24507 max: 26.4701. That would be my first guess. Especially because you run in PISO mode
Keep foaming,
Tobias Holzmann
Old   February 7, 2017, 11:21
Antoine
Thanks for your quick answer Tobi.
Yes I tried this as well and the solver crashes during the third time step. Here is the log file.
Build : 4.1
Date : Feb 07 2017
Time : 15:16:35
PID : 30239
nProcs : 1
Create time
type heRhoThermo;
thermo hPolynomial;
specie specie;
Reading field U
Reading g
Reading hRef
Reading field p_rgh
Creating field dpdt
Starting time loop
deltaT = 1.2e-10
Time = 1.2e-10
PIMPLE: iteration 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.66064e-19, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.0546701, Final residual = 1.0306e-22, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00887971, No Iterations 77
time step continuity errors : sum local = 1.05398e-16, global = 3.9305e-17, cumulative = 3.9305e-17
DICPCG: Solving for p_rgh, Initial residual = 0.491793, Final residual = 0.00240797, No Iterations 75
time step continuity errors : sum local = 1.4897e-16, global = 4.3335e-17, cumulative = 8.264e-17
DICPCG: Solving for p_rgh, Initial residual = 0.57848, Final residual = 0.00314953, No Iterations 75
time step continuity errors : sum local = 1.4878e-16, global = 4.3335e-17, cumulative = 1.25975e-16
DICPCG: Solving for p_rgh, Initial residual = 0.586074, Final residual = 8.47746e-09, No Iterations 155
time step continuity errors : sum local = 1.38492e-16, global = 4.4141e-17, cumulative = 1.70116e-16
ExecutionTime = 0.12 s ClockTime = 0 s
Courant Number mean: 5.2325e-16 max: 2.01354e-14
deltaT = 1.44e-10
Time = 2.64e-10
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 0.375238, Final residual = 5.06174e-17, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.425447, Final residual = 1.02992e-16, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.376789, Final residual = 9.52503e-17, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.109804, Final residual = 2.35794e-17, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 0.95771, Final residual = 12.2972, No Iterations 1001
time step continuity errors : sum local = 1.12464e-13, global = -7.97004e-17, cumulative = 9.04156e-17
DICPCG: Solving for p_rgh, Initial residual = 0.969428, Final residual = 0.00897822, No Iterations 8
time step continuity errors : sum local = 1.06168e-14, global = -8.09331e-17, cumulative = 9.4825e-18
DICPCG: Solving for p_rgh, Initial residual = 0.725705, Final residual = 0.00585134, No Iterations 11
time step continuity errors : sum local = 1.01544e-14, global = -8.03642e-17, cumulative = -7.08817e-17
DICPCG: Solving for p_rgh, Initial residual = 0.705409, Final residual = 1.3606, No Iterations 1001
time step continuity errors : sum local = 7.04522e-14, global = -8.13598e-17, cumulative = -1.52242e-16
ExecutionTime = 0.36 s ClockTime = 0 s
Courant Number mean: 8.14634e-14 max: 2.0581e-13
deltaT = 1.728e-10
Time = 4.368e-10
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 0.389284, Final residual = 6.39416e-16, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.374786, Final residual = 6.94543e-17, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.636027, Final residual = 1.45355e-16, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.996707, Final residual = 6.67237e-16, No Iterations 1
DICPCG: Solving for p_rgh, Initial residual = 0.808542, Final residual = 1.16481e+09, No Iterations 1001
time step continuity errors : sum local = 0.000418179, global = -2.55172e-13, cumulative = -2.55324e-13
DICPCG: Solving for p_rgh, Initial residual = 0.999999, Final residual = 0.00614212, No Iterations 13
time step continuity errors : sum local = 2.56852e-06, global = -2.55169e-13, cumulative = -5.10493e-13
DICPCG: Solving for p_rgh, Initial residual = 0.99982, Final residual = 0.00569006, No Iterations 14
time step continuity errors : sum local = 1.46772e-08, global = -2.55171e-13, cumulative = -7.65664e-13
DICPCG: Solving for p_rgh, Initial residual = 0.96881, Final residual = 4.72076, No Iterations 1001
time step continuity errors : sum local = 7.21886e-08, global = -2.5517e-13, cumulative = -1.02083e-12
ExecutionTime = 0.61 s ClockTime = 0 s
Courant Number mean: 1.41177e-07 max: 3.2514e-07
deltaT = 2.0736e-10
Time = 6.4416e-10
PIMPLE: iteration 1
DILUPBiCG: Solving for Ux, Initial residual = 0.376711, Final residual = 2.2168e-15, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.412434, Final residual = 2.2696e-15, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.420672, Final residual = 2.49295e-15, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 6.01906e-15, No Iterations 1
FOAM aborting
#4 ? at ??:?
#6 ? at ??:?
Many thanks,
Antoine
Old   February 7, 2017, 11:29
Tobi's Avatar
Tobias Holzmann
Your p_rgh solver has problems:
  • You should use GAMG solver for pressure (speed up)
  • However, this will not solve your problem
  • Mesh problem
  • But I think you have a BC problem
Good luck,
Keep foaming,
Tobias Holzmann
Old   February 9, 2017, 08:51
Antoine
Thanks for your advice Tobias. I will investigate.
Cheers,
Antoine
Old   July 17, 2017, 15:07
Antoine
Dear All,
In case some of you are interested, the problem was while using polynomial density or boussinesq approximation in the case of a closed volume with buoyantPimpleFoam. The bug was reported and corrected in the lastest version of OpenFOAM-dev. (https://bugs.openfoam.org/view.php?id=2617)
Best regards,
Antoine
Old   June 16, 2018, 14:21
Artur's Avatar
Artur
Artur will become famous soon enough
Hi All,
I know this is a bit of an old thread but I'm struggling with the exact same issue as Tobi did, namely when I try to simulate a hot water jet entering a large body of water with polynomial equations for state my density solution exceeds the maximum no. iterations. I'd like to simulate something similar to this thesis:
http://www.diva-portal.org/smash/get...421/FULLTEXT01
I gather it's the polynomials themselves that are causing the issue but I'm clueless as to how to fix this. Does anyone have any successful example cases for such a problem?
Funnily enough, my case works fine with buoyantBoussinesqSimpleFoam.
Thanks,
Artur
Artur is offline   Reply With Quote
Old   June 16, 2018, 16:15
Antoine
Hi!
Which version are you using? I think the bug I mentioned in a previous post was corrected in OpenFOAM 4.x.
Otherwise is the term dpdt set to off or no in your thermophysical file?
Regards,
Antoine
Old   June 16, 2018, 16:56
Artur's Avatar
Artur
Thanks for the prompt reply. I'm using 5.0 and at the moment not, I didn't have the unsteady term switched off. I'll try to see how to do it but if you could let me know that would also be great
Artur
EDIT: okay, just tried and it didn't change anything. I also tried to fix the density, viscosity, kappa and Cp by setting the constant term of the polynomials to the correct value and the rest to zero but to no avail.
EDIT 2: I posted my case with the mesh here, if anyone who knows more about this category of solvers would like to have a look it'd be much appreciated!
https://www.dropbox.com/s/b4hu90ajdn...le.tar.gz?dl=0
Old   June 22, 2018, 03:39
Artur's Avatar
Artur
Hi All,
After some intense figuring out and help from Antoine I managed to get the case working. The trick seems to be in using a temperature and velocity limiter for the first few iterations to allow the solver to cope with the admittedly complicated BC set up that my case has. You just need to put the attached fvOptions file in the constant directory and then comment the limiters out later on (or just make sure the limits have a sensible margin in the first place I guess).
All the best,
A
fvOptions.txt
arvindpj likes this.
Old   June 22, 2018, 12:20
Tobi's Avatar
Tobias Holzmann
Just one question. Do you start with a steady state solver?
Keep foaming,
Tobias Holzmann
