October 29, 2013, 04:30 |
Micro Scale Pore, icoFoam
Reza
Rep Power: 14 |
Hi FOAMers,
I'm working with icoFoam, incompressible fluid (water) in a very tiny pores (diameter is about 2-10 micrometers). I tried many boundary conditions such as: inlet: pressure: zeroGradient, velocity: fixedValue outlet: pressure: fixedValue, velocity: fixedValue or: inlet: pressure: fixedValue, velocity: pressureInletVelocity outlet: pressure: fixedValue, velocity: fixedValue As simulation starts, Courant number start to increase and maybe after 30 time step, it reaches to 10+4, and velocity and pressure values reach 10+10. I thought it could be because of high boundary condition in fixedValues but decrease in the B.C. just postpones the 30 time step to maybe 50 time step. Now I'm confusing with the data and how I can converge the simulation and your comments can help me a lot. Thanks To add more information, the log file is as follow: (from 16) [QUOTE]Time = 16 Courant Number mean: 0.153578 max: 20.706 DICPCG: Solving for Ux, Initial residual = 0.586454, Final residual = 6.91785e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.574148, Final residual = 9.70984e-06, No Iterations 26 DICPCG: Solving for Uz, Initial residual = 0.579967, Final residual = 8.64667e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915668, Final residual = 0.00341124, No Iterations 1001 time step continuity errors : sum local = 0.000298567, global = -1.18248e-18, cumulative = -9.13022e-19 DICPCG: Solving for p, Initial residual = 0.713102, Final residual = 0.00340517, No Iterations 1001 time step continuity errors : sum local = 0.000346162, global = 5.90852e-20, cumulative = -8.53937e-19 ExecutionTime = 553.09 s ClockTime = 554 s Time = 17 Courant Number mean: 0.327887 max: 45.4381 DICPCG: Solving for Ux, Initial residual = 0.578642, Final residual = 7.07612e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.567511, Final residual = 9.88047e-06, No Iterations 26 DICPCG: Solving for Uz, Initial residual = 0.576988, Final residual = 8.42121e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.914977, Final residual = 0.00390539, No Iterations 1001 time step continuity errors : sum local = 0.000717964, global = -1.87682e-18, cumulative = -2.73076e-18 DICPCG: Solving for p, Initial residual = 0.711657, Final residual = 0.00392582, No Iterations 1001 time step continuity errors : sum local = 0.000839034, global = 2.6569e-19, cumulative = -2.46507e-18 ExecutionTime = 594.15 s ClockTime = 595 s Time = 18 Courant Number mean: 0.707737 max: 99.7878 DICPCG: Solving for Ux, Initial residual = 0.576575, Final residual = 7.24442e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.571475, Final residual = 6.69346e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.580093, Final residual = 8.40165e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915265, Final residual = 0.00503088, No Iterations 1001 time step continuity errors : sum local = 0.00198916, global = -7.13966e-18, cumulative = -9.60473e-18 DICPCG: Solving for p, Initial residual = 0.712068, Final residual = 0.00362861, No Iterations 1001 time step continuity errors : sum local = 0.00168029, global = -2.94268e-19, cumulative = -9.89899e-18 ExecutionTime = 633.22 s ClockTime = 635 s Time = 19 Courant Number mean: 1.54739 max: 219.104 DICPCG: Solving for Ux, Initial residual = 0.571621, Final residual = 7.2858e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.567273, Final residual = 6.75068e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.579016, Final residual = 8.25097e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.914407, Final residual = 0.00501194, No Iterations 1001 time step continuity errors : sum local = 0.00427993, global = 1.98959e-18, cumulative = -7.90941e-18 DICPCG: Solving for p, Initial residual = 0.710811, Final residual = 0.00470349, No Iterations 1001 time step continuity errors : sum local = 0.00469284, global = -2.94113e-18, cumulative = -1.08505e-17 ExecutionTime = 674.02 s ClockTime = 676 s Time = 20 Courant Number mean: 3.38704 max: 482.002 DICPCG: Solving for Ux, Initial residual = 0.575768, Final residual = 7.49024e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.573837, Final residual = 6.84839e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.583038, Final residual = 8.35092e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915017, Final residual = 0.00402223, No Iterations 1001 time step continuity errors : sum local = 0.00757513, global = -1.80299e-17, cumulative = -2.88804e-17 DICPCG: Solving for p, Initial residual = 0.711456, Final residual = 0.00311159, No Iterations 1001 time step continuity errors : sum local = 0.00690337, global = 6.73494e-19, cumulative = -2.82069e-17 ExecutionTime = 713.38 s ClockTime = 715 s Time = 21 Courant Number mean: 7.45941 max: 1058.67 DICPCG: Solving for Ux, Initial residual = 0.564429, Final residual = 7.42311e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.568091, Final residual = 6.94978e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.578544, Final residual = 8.29321e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.913466, Final residual = 0.00547878, No Iterations 1001 time step continuity errors : sum local = 0.0222682, global = -4.48831e-17, cumulative = -7.309e-17 DICPCG: Solving for p, Initial residual = 0.708487, Final residual = 0.00505239, No Iterations 1001 time step continuity errors : sum local = 0.0239581, global = 1.65593e-17, cumulative = -5.65307e-17 ExecutionTime = 754.78 s ClockTime = 757 s Time = 22 Courant Number mean: 16.3605 max: 2333.46 DICPCG: Solving for Ux, Initial residual = 0.575591, Final residual = 7.66668e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.576227, Final residual = 6.96544e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.58572, Final residual = 8.32394e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915282, Final residual = 0.00447722, No Iterations 1001 time step continuity errors : sum local = 0.0406606, global = -1.36231e-16, cumulative = -1.92762e-16 DICPCG: Solving for p, Initial residual = 0.71164, Final residual = 0.00335635, No Iterations 1001 time step continuity errors : sum local = 0.0360795, global = -2.07856e-17, cumulative = -2.13548e-16 ExecutionTime = 794.76 s ClockTime = 797 s Time = 23 Courant Number mean: 36.4055 max: 5133.06 DICPCG: Solving for Ux, Initial residual = 0.563589, Final residual = 7.56456e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.569976, Final residual = 7.02741e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.580772, Final residual = 8.27355e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912983, Final residual = 0.00583355, No Iterations 1001 time step continuity errors : sum local = 0.11506, global = 2.93421e-16, cumulative = 7.98734e-17 DICPCG: Solving for p, Initial residual = 0.707404, Final residual = 0.00524665, No Iterations 1001 time step continuity errors : sum local = 0.12082, global = 2.5704e-17, cumulative = 1.05577e-16 ExecutionTime = 834.12 s ClockTime = 836 s Time = 24 Courant Number mean: 79.7652 max: 11332.9 DICPCG: Solving for Ux, Initial residual = 0.574767, Final residual = 7.7861e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.580135, Final residual = 7.03556e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.58724, Final residual = 8.29394e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915, Final residual = 0.00465197, No Iterations 1001 time step continuity errors : sum local = 0.205391, global = 2.22438e-17, cumulative = 1.27821e-16 DICPCG: Solving for p, Initial residual = 0.710842, Final residual = 0.00367794, No Iterations 1001 time step continuity errors : sum local = 0.192344, global = 1.45524e-16, cumulative = 2.73345e-16 ExecutionTime = 872.17 s ClockTime = 874 s Time = 25 Courant Number mean: 177.756 max: 24947.8 DICPCG: Solving for Ux, Initial residual = 0.563286, Final residual = 7.66645e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.571524, Final residual = 7.03783e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.581587, Final residual = 8.22364e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912806, Final residual = 0.00614089, No Iterations 1001 time step continuity errors : sum local = 0.591813, global = 1.12307e-16, cumulative = 3.85652e-16 DICPCG: Solving for p, Initial residual = 0.707011, Final residual = 0.00556059, No Iterations 1001 time step continuity errors : sum local = 0.62673, global = 8.22528e-17, cumulative = 4.67905e-16 ExecutionTime = 912.49 s ClockTime = 915 s Time = 26 Courant Number mean: 390.775 max: 55080.8 DICPCG: Solving for Ux, Initial residual = 0.575144, Final residual = 7.90521e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.581466, Final residual = 7.06778e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.588583, Final residual = 8.27456e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.914581, Final residual = 0.0057074, No Iterations 1001 time step continuity errors : sum local = 1.23604, global = 3.7251e-15, cumulative = 4.19301e-15 DICPCG: Solving for p, Initial residual = 0.710382, Final residual = 0.00466448, No Iterations 1001 time step continuity errors : sum local = 1.19823, global = 1.17052e-16, cumulative = 4.31006e-15 ExecutionTime = 951.71 s ClockTime = 954 s Time = 27 Courant Number mean: 870.556 max: 121252 DICPCG: Solving for Ux, Initial residual = 0.565781, Final residual = 7.76904e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.576009, Final residual = 7.07257e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.584752, Final residual = 8.26019e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912841, Final residual = 0.00737126, No Iterations 1001 time step continuity errors : sum local = 3.50482, global = -9.23762e-16, cumulative = 3.3863e-15 DICPCG: Solving for p, Initial residual = 0.706756, Final residual = 0.00638689, No Iterations 1001 time step continuity errors : sum local = 3.55537, global = 1.39197e-16, cumulative = 3.52549e-15 ExecutionTime = 997.25 s ClockTime = 1000 s Time = 28 Courant Number mean: 1917.05 max: 268059 DICPCG: Solving for Ux, Initial residual = 0.578745, Final residual = 8.04913e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.587058, Final residual = 7.13481e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.592451, Final residual = 8.33298e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.914639, Final residual = 0.00718143, No Iterations 1001 time step continuity errors : sum local = 7.70859, global = 8.47836e-15, cumulative = 1.20039e-14 DICPCG: Solving for p, Initial residual = 0.709951, Final residual = 0.00588492, No Iterations 1001 time step continuity errors : sum local = 7.50459, global = -3.2648e-15, cumulative = 8.73906e-15 ExecutionTime = 1043.17 s ClockTime = 1046 s Time = 29 Courant Number mean: 4281.41 max: 590512 DICPCG: Solving for Ux, Initial residual = 0.56918, Final residual = 7.89289e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.580022, Final residual = 7.09539e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.587747, Final residual = 8.34433e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912823, Final residual = 0.00934463, No Iterations 1001 time step continuity errors : sum local = 22.132, global = 6.51948e-14, cumulative = 7.39339e-14 DICPCG: Solving for p, Initial residual = 0.705882, Final residual = 0.00851879, No Iterations 1001 time step continuity errors : sum local = 23.6354, global = -7.08639e-16, cumulative = 7.32252e-14 ExecutionTime = 1082.95 s ClockTime = 1086 s Time = 30 Courant Number mean: 9421.37 max: 1.3039e+06 DICPCG: Solving for Ux, Initial residual = 0.580493, Final residual = 8.15774e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.589421, Final residual = 7.1739e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.595603, Final residual = 8.43067e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915033, Final residual = 0.00989074, No Iterations 1001 time step continuity errors : sum local = 52.94, global = 2.64221e-13, cumulative = 3.37447e-13 DICPCG: Solving for p, Initial residual = 0.70866, Final residual = 0.00759285, No Iterations 1001 time step continuity errors : sum local = 48.2584, global = -3.66974e-14, cumulative = 3.00749e-13 ExecutionTime = 1123.09 s ClockTime = 1126 s Time = 31 Courant Number mean: 21008.3 max: 2.86799e+06 DICPCG: Solving for Ux, Initial residual = 0.570359, Final residual = 7.92147e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.582074, Final residual = 7.11416e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.590417, Final residual = 8.38927e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.91296, Final residual = 0.00906945, No Iterations 1001 time step continuity errors : sum local = 106.611, global = 2.10567e-13, cumulative = 5.11316e-13 DICPCG: Solving for p, Initial residual = 0.705608, Final residual = 0.00868781, No Iterations 1001 time step continuity errors : sum local = 119.384, global = -1.2958e-14, cumulative = 4.98358e-13 ExecutionTime = 1160.86 s ClockTime = 1164 s Time = 32 Courant Number mean: 46098.2 max: 6.32056e+06 DICPCG: Solving for Ux, Initial residual = 0.581733, Final residual = 8.11783e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.59222, Final residual = 7.14387e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.598781, Final residual = 8.47531e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.915125, Final residual = 0.00708628, No Iterations 1001 time step continuity errors : sum local = 186.854, global = -1.05587e-12, cumulative = -5.57514e-13 DICPCG: Solving for p, Initial residual = 0.708802, Final residual = 0.00626718, No Iterations 1001 time step continuity errors : sum local = 196.182, global = 9.41478e-14, cumulative = -4.63367e-13 ExecutionTime = 1202.01 s ClockTime = 1205 s Time = 33 Courant Number mean: 103020 max: 1.39021e+07 DICPCG: Solving for Ux, Initial residual = 0.571668, Final residual = 7.98765e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.583149, Final residual = 7.10919e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.59027, Final residual = 8.39816e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912472, Final residual = 0.00808608, No Iterations 1001 time step continuity errors : sum local = 464.499, global = 8.3174e-13, cumulative = 3.68374e-13 DICPCG: Solving for p, Initial residual = 0.704891, Final residual = 0.00771748, No Iterations 1001 time step continuity errors : sum local = 518.214, global = -1.10143e-13, cumulative = 2.58231e-13 ExecutionTime = 1241.57 s ClockTime = 1245 s Time = 34 Courant Number mean: 225213 max: 3.06589e+07 DICPCG: Solving for Ux, Initial residual = 0.579956, Final residual = 8.16306e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.58882, Final residual = 7.13879e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.593815, Final residual = 8.4357e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.914487, Final residual = 0.00899155, No Iterations 1001 time step continuity errors : sum local = 1149.99, global = 1.13706e-12, cumulative = 1.39529e-12 DICPCG: Solving for p, Initial residual = 0.707044, Final residual = 0.00698948, No Iterations 1001 time step continuity errors : sum local = 1060.53, global = -2.30004e-13, cumulative = 1.16529e-12 ExecutionTime = 1279.49 s ClockTime = 1285 s Time = 35 Courant Number mean: 498495 max: 6.73873e+07 DICPCG: Solving for Ux, Initial residual = 0.571961, Final residual = 8.0269e-06, No Iterations 26 DICPCG: Solving for Uy, Initial residual = 0.58522, Final residual = 7.16413e-06, No Iterations 27 DICPCG: Solving for Uz, Initial residual = 0.591963, Final residual = 8.47402e-06, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.912914, Final residual = 0.0104296, No Iterations 1001 time step continuity errors : sum local = 2924.92, global = -2.51385e-12, cumulative = -1.34856e-12 DICPCG: Solving for p, Initial residual = 0.705036, Final residual = 0.00970701, No Iterations 1001 time step continuity errors : sum local = 3184.13, global = 1.13382e-12, cumulative = -2.14735e-13 ExecutionTime = 1318.78 s ClockTime = 1325 s Time = 36 /QUOTE] Last edited by gooya_kabir; October 29, 2013 at 10:52. |
October 30, 2013, 07:21 |
Reza
Rep Power: 14 |
again Hi
as you see the above description, in solving pressure there is a time step continuity error, could be the problem this? should I decrease the time step? I do not think it affect in icoFoam? thanks |
November 2, 2013, 14:58 |
Robert
Rep Power: 14 |
You should! The courant number should always stay below 1.
icofoam |
Attempt to run rhoPisoTwinParcelFoam on micro scale | jabecker | OpenFOAM Running, Solving & CFD | 3 | April 13, 2021 09:52 |
micro scale calculation problem | Guava Wang | Main CFD Forum | 8 | July 13, 2012 00:07 |
micro scale centrifugal separator | devalpandya | FLUENT | 0 | February 3, 2010 01:08 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 01:36 |
how to find the talor micro scale from DNS data | hanman | Main CFD Forum | 0 | March 8, 2006 05:51 |
