Message truncated, error stack: MPIDI_CH3U_Receive_data_found
Like Tree1Likes
Old   June 24, 2016, 05:51
pante is on a distinguished road
Hi everybody,
I am facing a similar problem and I really cannot understand what is going wrong. I am using OpenFOAM 2.2.x. and I am trying to implement the PatchFlowRateInjection of OpenFOAM 2.4.x in my version of the code.
The code is working ok if I use the setPositionandCell member function of version 2.2.x. But when I try to use the patchInjectionBase::setPositionandCell of
OpenFOAM 2.4.x, which I 've manage to use with success in another injector I 've created without any errors,
the code, after running for some timeSteps, it suddenly crashes with the following error:
"Fatal error in MPI_Recv: Message truncated, error stack:
MPI_Recv(198)...........................: MPI_Recv(buf=0x7ffff2cf26c0, count=4, MPI_PACKED, src=0, tag=1, MPI_COMM_WORLD, status=0x7ffff2cf2650) failed
MPIDI_CH3_PktHandler_EagerShortSend(443): Message from rank 0 and tag 1 truncated; 8 bytes received but buffer size is 4".
The same code runs ok in serial. I notice that the problem occurs at
Pstream::scatter(areaFraction);
So one of the processors fails to receive the data from the master proc.
commsType is set to nonBlocking.
I would really appreciate any help on that.
Thanks, Pante
pante is offline   Reply With Quote
Old   November 19, 2021, 02:20
Yanyan Xie
imastrid is on a distinguished road
Originally Posted by pante View Post
Hi everybody,
Thanks, Pante
Hi, Pante
I'm facing the similar problem. Do you remember how you solved the problem?
Thanks,
Yanyan
imastrid is offline   Reply With Quote
Guide: Getting Started with the CFD Online Discussion Forums pete Site Help, Feedback & Discussions 8 July 29, 2016 06:00
single directional message transmit in parallel model su_junwei OpenFOAM Programming & Development 1 December 17, 2009 08:00
Error message in CFX-10 CFDworker CFX 2 October 12, 2007 08:23
error message susan Siemens 0 August 17, 2007 01:27
MPI Message truncated josef OpenFOAM Running, Solving & CFD 1 January 9, 2006 07:29
