Turbulence Models: kOmegaSST for different Reynolds Numbers |
October 25, 2013, 14:02 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
I have just a very simple question to you. The last week I made a complex simulation of a static mixing element in a pipe. I simulated with kOmegaSST and simpleFoam. The first calculation was with the following conditions: Code:
massflow: 30 kg/h temperature: 200°C Re: 3840 After that I calculated the same with new conditions: Code:
massflow: 1000 kg/h temperature: 200°C Re: 128007 My question is now. Could it be possible that the kOmegaSST model is inaccurat in a low turbulence flow? What should I use there instead? Compared with the residuals of the highMassFlow.png I am wondering why its more stable that with low mass flow. And is the turbulence model causing the instability of the calculation? Thanks in advance for any hint. Tobi |
February 10, 2014, 18:40 |
Joachim Herb
Rep Power: 22 |
Hi Tobi,
did you find a reason for the bad residuals of the low mass flow case? Joachim |
May 12, 2014, 08:48 |
Tobias Holzmann
Rep Power: 52 |
Hey Joachim,
sorry for the late answer but there I was not investigate more time because it was only an own project. I think the BC were bad
Keep foaming, Tobias Holzmann |
CFX Spalart Allmaras turbulence models | aweizazuji | CFX | 9 | September 24, 2013 11:53 |
Turbulence models become invalid at Re=2000~5000? | liweif | FLUENT | 9 | August 27, 2007 12:55 |
HELP!! Prandtl numbers in RNG k-e turbulence model | maoasis | FLUENT | 0 | April 24, 2006 11:51 |
turbulence models? | haider | FLUENT | 0 | March 8, 2006 00:58 |
Turbulence Models and external flow. | Alan | FLUENT | 3 | November 22, 2005 05:46 |
