Temperature Distribution problem ScalarTransportFoam
Old   October 25, 2013, 12:12
Default Temperature Distribution problem ScalarTransportFoam
João Ferreira
Hotjuan is on a distinguished road
i'm working scalarTransportFoam trying to get temperature distribution on a wall with internal heat generation (q=1000kW/m3), one face with 100ºC and another with 200ºC imposed.
My problem's with fvOptions. How can i add the internal heat generation source term in fvOptions? Anyone made something similar?
Thank you and best regards
Hotjuan is offline   Reply With Quote
Old   November 19, 2013, 16:00
Alex
zfaraday will become famous soon enough
I'm also interested in the answer! I'm working with something similar but I haven't found the way to solve it...
Thanks in advance!
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   November 20, 2013, 06:41
Olivier
olivierG is on a distinguished road
hello,
I think there is not such ready to use fvOption source for heat generation (i.e W or W/m3 source). You can have it for T, but this is [K], not Watt. You also can constraint T value, but not the heat source directly.
So the solution is to use the "codedSource" ... but this need a little codding stuf.
regards,
olivier
olivierG is offline   Reply With Quote
Old   November 20, 2013, 11:20
Alex
Yes, you are right. But as heat flows through a solid according to the expression
q/A = -k*dT/dx
maybe we could do something with the gradT. That's what I first thought... Maybe working with swak4foam...
Old   December 4, 2013, 14:27
Laurien Vandewalle
lavdwall is on a distinguished road
Can someone give me an example of the usage of codedSource in fvOptions? What exactly are codeCorrect, codeAddSup and codeSetValue?
lavdwall is offline   Reply With Quote
Old   December 7, 2013, 15:28
João Ferreira
to solve this problem, i used fvOptions with scalarSemiImplicitSource.
Where the Su term (first one) is the internal heat transfer and thats solved!
HTML Code:
Source
    type            scalarSemiImplicitSource;
    active          true;
    selectionMode   all;
    scalarSemiImplicitSourceCoeffs
        volumeMode     specific;
        injectionRateSuSp
             T       (0 0);
Best regards.
PorousMedia Problem with Temperature Distribution pawan OpenFOAM Running, Solving & CFD 2 August 3, 2015 00:08
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
temperature distribution problem in a fluid-solid coupled case ryanmoser FLUENT 4 September 2, 2012 06:35
static temperature is higher than total temp. in buoyancy problem amirbahador FLUENT 2 October 24, 2010 08:21
Temperature distribution in a solid michael_krobath OpenFOAM Running, Solving & CFD 3 August 29, 2007 08:12
