May 12, 2015, 16:58 |
#21 |
Phil.
Henning, thanks! I am new to OpenFOAM source code. Could you please explain why there are two sets of RK4values (RK4values and RK4values2)?
-------------------------- Plz ignore this question. I've found the classical 4th RK in Jameson's paper. Last edited by philem; May 15, 2015 at 12:04. |
June 18, 2015, 13:12 |
#22 |
Rep Power: 15 |
Thank you for your code.
I have been working with rhoCentralFoam solver several years. And I have some problem. Does anyone has the follow problem: rhocentralFoam is good working in 3d cases, BUT only with UPWIND reconstruct scheme? If I change to vanleer scheme or other(gamma, superbee) the solver crashed. Also I tried different grad scheme but it has no result. This problem is present in all my tasks: external flow at M~2-4 or jet stream from nozzle. Thanks. |
July 20, 2016, 03:58 |
#23 |
Marko Josic
Rep Power: 16 |
Hallo,
i have/had the same problem. Does anybody know the discretization settings for a second order in time and space? with "backward" the solver crashes, and Euler is only first order and for my unsteady problem to diffusive. and for spatial dissertation is the same problem, only "upwind" works, any other higher order discretization with limiter function produces overshoots, when i compare the numerical with the analytical solution. |
November 3, 2016, 10:01 |
#24 |
Wenkun Zhao
Rep Power: 11 |
Hi Henning,
I am quite interested in your rhoCentralFoamRK4 and how about the results compared to rhoCentralFoam? Have you ever calculated some cases and compared with other results obtained by FLUNET etc. Best Eric |
December 13, 2016, 11:12 |
RK4 - rhoCentralFoam
#25 |
Rep Power: 11 |
Hello everyone,
I am trying to implement RK4 for rhoCentralFoam as well. I want to clarify a couple of issues pertaining to Henning86's implementation first.
On a separate note, I would like to know whether it is feasible to implement RK4 as a standalone ddtScheme like EulerDdtScheme because, so far, I don't think it is possible. It would be extremely helpful if anyone could enlighten me on these issues. Many thanks, USV |
Main advantage of using Runge Kutta of higher order? | jakubstary | Main CFD Forum | 14 | August 20, 2019 17:15 |
1D Burgers euqation with 4th Runge Kutta | dokeun | Main CFD Forum | 3 | August 8, 2011 07:34 |
Runge Kutta Discontinuous Galerkin procedure? | Ameya J | Main CFD Forum | 6 | July 29, 2011 06:56 |
Runge Kutta Optimization | vasanth | Main CFD Forum | 6 | December 2, 2005 14:07 |
Diagonally Dominate Runge Kutta Method | Anthony Iannetti | Main CFD Forum | 0 | January 23, 2001 22:27 |
