Courant number blowing up, non-orthogonal mesh?
Old   October 21, 2013, 05:14
Default Courant number blowing up, non-orthogonal mesh?
Olie
odellar is on a distinguished road
I'm trying to run a case I created with a backward facing step geometry, using the k-epsilon turbulence model, RAS solver. I've created the mesh and when I run blockMesh it creates the mesh (which when I view in ParaView looks correct) but gives some warnings:
Create time
Creating block mesh from
    "/home/olie/OpenFOAM/olie-2.2.1/run/tutorials/incompressible/pisoFoam/ras/bfstep/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
    From function cellModel::mag(const labelList&, const pointField&)
    in file meshes/meshShapes/cellModel/cellModel.C at line 128
    zero or negative pyramid volume: -0.666667 for face 0
--> FOAM Warning :
    zero or negative pyramid volume: -0.666667 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -0.666667 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -0.666667 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -0.666667 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -0.666667 for face 5
--> FOAM Warning :
    From function blockMesh::createTopology(IOdictionary&)
    in file blockMesh/blockMeshTopology.C at line 255
    negative volume block : 0, probably defined inside-out
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 0
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -2.66667 for face 5
--> FOAM Warning :
    negative volume block : 1, probably defined inside-out
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
    negative volume block : 2, probably defined inside-out
Check topology
    Basic statistics
        Number of internal faces : 2
        Number of boundary faces : 14
        Number of defined boundary faces : 14
        Number of undefined boundary faces : 0
    Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 1
Writing polyMesh
Mesh Information
  boundingBox: (0 -2 0) (10 2 1)
  nPoints: 1942
  nCells: 900
  nFaces: 3670
  nInternalFaces: 1730
Patches
  patch 0 (start: 1730 size: 10) name: inlet
  patch 1 (start: 1740 size: 20) name: outlet
  patch 2 (start: 1760 size: 110) name: fixedWalls
  patch 3 (start: 1870 size: 1800) name: frontAndBack
End
When I then run pisoFoam it fails and says:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    sigmaEps        1.3;
Starting time loop
Time = 0.001
Courant Number mean: 1.66667e+295 max: 1.5e+297
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  void Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::Field<Foam::Vector<double> >&, Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5   at gaussDivSchemes.C:0
#6  Foam::fv::gaussDivScheme<Foam::Tensor<double> >::fvcDiv(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::tmp<Foam::GeometricField<Foam::innerProduct<Foam::Vector<double>, Foam::Tensor<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<Foam::Tensor<double> >(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so"
#8  Foam::incompressible::RASModels::kEpsilon::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
 in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/pisoFoam"
#10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
Floating point exception (core dumped)
So the Courant number blows up immediately. I don't think it's an issue with my choice of time step, I've been very careful to choose it to satisfy Co<1.
I'd be very grateful if someone could help me out!
Thanks,
Olie
odellar is offline   Reply With Quote
Old   October 22, 2013, 11:43
Eric Robertson
msuaeronautics is on a distinguished road
You need to re-mesh. Seems like you have some mesh quality issues- most specifically, inside-out cells.
msuaeronautics is offline   Reply With Quote
Old   October 22, 2013, 15:22
Olie
Okay, thank you.
Now what exactly does that mean? Made a mistake with the way I defined blocks or something? Maybe the order of the vertices I give?
Thanks for pointing that out.
Old   October 22, 2013, 15:25
Eric Robertson
That's what it seems like. You must also remember to follow the right hand rule when defining block faces etc.
Old   October 22, 2013, 16:57
Olie
Thank you - I had a look at the way I'd defined blocks and faces and it would appear I didn't follow the RHR. So I've got it to run now, HOWEVER the mesh isn't using the same x-y-z coordinates as me it would seem. For example I have three blocks, which in blockMeshDict I've declared:
blocks
hex (11 12 4 3 8 9 1 0) (10 10 1) simpleGrading (1 1 1)//0
hex (12 13 5 4 9 10 2 1) (40 10 1) simpleGrading (1 1 1)//1
hex (14 15 7 6 12 13 5 4) (40 10 1) simpleGrading (1 1 1)//2
- so I mean to have 10 cells in x, 10 in y, and 1 in z (first block), 40 cells in x, 10 in y, 1 in z (second block).. etc.. HOWEVER when I look at the mesh in Paraview it seems to be producing me the right outline geometrical shape, but with 10 cells in x, 1 in y, and 10 in z (first block), 40 cells in x, 1 in y, and 10 in z (second block).. etc..
I.e. it's mixed up my mesh resolutions in the y & z directions - do you know why this is?
Thanks for the help.
Olie
Old   October 22, 2013, 20:50
Alex
zfaraday will become famous soon enough
Hi odellar!
Read carefully the section 5.3 of the User Guide http://www.openfoam.org/docs/user/blockMesh.php. It's important to understand the use of the "local coordinate system" when you create your blocks and the difference between both local and global coordinate systems, which is what you see in paraview.
cheers.
zfaraday
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
[ICEM] courant number <-> mesh quality kpax ANSYS Meshing & Geometry 7 December 20, 2012 12:06
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
