How to calculate and write out transient drag / lift coefficient in OpenFOAM 2.2.1?
Old   October 19, 2013, 05:03
Default How to calculate and write out transient drag / lift coefficient in OpenFOAM 2.2.1?
Yao Lu
shuoxue is on a distinguished road
It seems that a keyword functions containing forces and forcesCoeffs should be added at the end of controlDict.
Is there any tutorial to give a typical example, and what's the meaning of each entry.
These two are founded on OpenFOAM forum.
functions
{ forces
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches (profile_wall)
pName p;
UName U;
log true;
rhoInf 1.225;
CofR ( 0 0 0 );
liftDir ( 0 1 0 );
dragDir (1 0 0 );
pitchAxis ( 0 0 1 );
magUInf 100.0;
lRef 0.1254;
Aref 0.01292;
functions
forces
type forces;
functionObjectLibs ( "libforces.so" ); // lib to load
outputInterval 1;
patches
wall // change to your patch name
// name of fields
pName p;
UName U;
log true; // dump to file
rhoInf 1025;
CofR ( 0 0 0 );
forcesCoeffs
type forceCoeffs;
outputInterval 1;
patches
// name of fields
pName p;
UName U;
rhoInf 1025;
CofR ( 0 0 0 );
liftDir ( 0 1 0 );
dragDir ( 1 0 0 );
pitchAxis ( 0 0 0 );
magUInf 7.30;
lRef 0.305;
Aref 0.001525;
Thanks in advance.
shuoxue is offline   Reply With Quote
Old   September 30, 2014, 17:01
Default execFlowFunctionObjects
mohammad
maghsomi is on a distinguished road
i use execFlowFunctionObjects but i have this problem
Time = 0.0008
Reading phi
Reading U
Reading p
Selecting incompressible transport model Newtonian
Selecting LES turbulence model oneEqEddy
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
--> FOAM Warning :
From function cubeRootVolDelta::calcDelta()
in file cubeRootVolDelta/cubeRootVolDelta.C at line 52
Case is 2D, LES is not strictly applicable
maghsomi is offline   Reply With Quote
Old   October 8, 2014, 05:10
Default Lift and drag
fluxent is on a distinguished road
There's in OF a function object that allows to evaluate lift and drag?...not coefficient.
Thank's in advance for your attention
fluxent is offline   Reply With Quote
Old   November 11, 2014, 06:04
er_trebbia is on a distinguished road
Hi fluxent
type this inside functions () in controlDict
forces
type forces;
functionObjectLibs ("libforces.so");
patches (//patches of wall you are calculating);
pName p;
UName U;
rhoName rhoInf;//for incompressible
rhoInf 1.2; // Reference density, fluid
CofR (0 0 0); // Origin for moment calculations
outputInterval 1;
You can find in tutorials/incompressible/pimpleDyMFoam/wingMotion/
Last edited by er_trebbia; November 15, 2014 at 06:51. Reason: previous was very rough
er_trebbia is offline   Reply With Quote
Old   November 16, 2023, 11:15
Rohan
Rohanbotta is on a distinguished road
Hi er_trebbia
can this give force coefficients or required forces to find Cl, Cd?
Thank you
Rohanbotta is offline   Reply With Quote
How to calculate and write out transient drag / lift coefficient in OpenFOAM 2.2.1? shuoxue OpenFOAM 1 October 19, 2013 12:51
how to write a scalar value to a file ???? SamerAli OpenFOAM Programming & Development 1 May 7, 2013 14:19
How calculate friction coefficient in a corrugated pipe Feli FLOW-3D 0 November 9, 2011 12:16
Drag coefficient as a solver criterium sanchezz CFX 1 January 4, 2010 19:30
interesting..how to calculate lift and drag distbn Endee FLUENT 1 August 30, 2005 19:54
