Particle simulation with transient flow field |
October 14, 2013, 21:19 |
India
Rep Power: 14 |
Hi Foamers,
I am running particle simulation using OF 2.1.1 in triple bifurcation geometries. Until now I used to calculate steady flow field first by running simpleFoam on the geometry then picked the 'U' file from last time folder and placed in '0' folder of particle case and executed icoUncoupledKinematicParcelFoam to solve for particles. Now I want to set up cases for one way coupled particle simulation with transient flow field. How can I give pre-defined velocity fields in this case? Regards, Mayank. |
October 15, 2013, 05:02 |
Rep Power: 20 |
If you need to solve a transient particle-transport problem then you need to create your own solver for that purpose. For incompressible flow problems you can use pisoFoam as a basis for your solver, and then inspect the source code for the other Lagrangian solvers to find out what you need to add.
Even tough it is possible to pre-calculate a velocity field and use that with icoUncoupledKinematicParcelFoam, I really do not think that it is a good idea. Doing that require loads of storage and leads to large overheads with respect to I/O, not to mention that you loose the possibility of running coupled fluid-particle simulations. |
October 15, 2013, 17:01 |
#3 | |
India
Rep Power: 14 |
I was also thinking the same regarding storage and overheads. Well, we already have solver available on the forum for calculating transient particle transport. Regards, Mayank. |
Coupling of drying process and flow simulation | franzdrs | Main CFD Forum | 0 | April 29, 2013 15:11 |
transient, impregnating flow problem | fgommer | FLUENT | 0 | February 29, 2012 17:10 |
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) | Julian K. | CFX | 2 | September 15, 2011 16:30 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 08:25 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 17:29 |
