solver for simulating floating body
Old   October 13, 2013, 17:55
Default solver for simulating floating body
maryam morta
mary mor is on a distinguished road
Hi FOAMers,
I'm new at OpenFoam and I need help to understand which solver I should start with.
My goal is to simulate a floating body under waves. I need a 6DOF solver and a VOF solver for free-surface beside a solver or boundary condition to generate waves. I faced with different solvers like shipFoam, rasInterFoam, NavyFoam for such a case.
I don't know which one is better to use and what are the differences. Which one get more convergent results? Do they need another 6DoF solver to calculate the displacement of the floating body?
I appreciate any help...
thanks
mary mor is offline   Reply With Quote
Old   October 18, 2013, 06:25
Artur's Avatar
Artur
Artur will become famous soon enough
Perhaps before you go off to check out modified solvers you'd want to have a look at $FOAM_TUTORIALS/multiphase/interDyMFoam/RAS/floatingObjec
There are also the sloshing tank tutorials in the same directory which have versions with various numbers of DoF.
Good luck,
A
Artur is offline   Reply With Quote
Old   October 19, 2013, 12:41
maryam morta
Thanks Artur
I've checked these tutorials. The floating object tutorial seems to help. Although I don't know how the displacements of the floating object is considered. Does it contain the 6DoF solver I'm searching for?
Besides I need to generate wave in the tank. As I searched, wave2Foam helps me to do this.
The slashing tank seems to impose a sinusoidal motion to the tank and I'm not sure if it's the thing I need...
Thanks in advance
Old   October 20, 2013, 11:49
Artur's Avatar
Artur
As for wave generation I think the package you mentioned is the best choice to start with, I know many people who use it. I suppose that groovyBc could also be used if the former didn't deliver all the stuff you are interested in.
As for 6DoF solvers in OF I am not an expert by no means, I just had a quick look at them some time ago. Hopefully someone more experienced will share some more experience with you if you get stuck. In the meantime, I think for your case it's worth looking at the following:
http://www.tfd.chalmers.se/~hani/kur...rikEkedahl.pdf
Good luck,
A
Old   October 21, 2013, 13:50
maryam morta
Thanks Artur
I've taken a quick look at this paper before. I will read it more carefully this time.
I hope someone help in case i got stuck.
Old   December 23, 2015, 15:31
Tia
atieh is on a distinguished road
Hi Foamers,
I run the tutorial at $FOAM_TUTORIALS/multiphase/interDyMFoam/RAS/floatingObjec.
To run: 1. blockMesh
2. setFields
3. topoSet
4. interDyMFOAM
It seems floating object doesn't move. I am using OF2.1.1. Could anybody let me know where went wrong? or How can see the floating object in the Paraview?
Atieh
atieh is offline   Reply With Quote
Old   November 15, 2022, 08:02
mechanicalhead is on a distinguished road
Originally Posted by atieh View Post
Hi Foamers,
2. setFields
3. topoSet
4. interDyMFOAM
Atieh
I live the same problem. Did you solve or Is anybody does know the solution? Thanks.
mechanicalhead is offline   Reply With Quote
different results between serial solver and parallel solver wlt_1985 FLUENT 11 October 12, 2018 09:23
3d vof Smaras FLUENT 2 February 19, 2013 07:58
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 12:00
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 08:45
cannot run solver if body spacing less than 1 wan CFX 1 February 28, 2008 17:41
