porousInterFoam - problem setting correct bcs
Old   October 8, 2013, 08:07
Default porousInterFoam - problem setting correct bcs
Natalie2210 is on a distinguished road
Dear all,
I'm working with the porousInterFoam solver. Currently, I'm trying to simulate two porous layers which have the same porosity but differ in their permeability. The fluid is injected laterally.
I expect the fluid to move through the layers at different velocities, resulting in an asymmetric flow front (see attachments, both pictures depict the volume fraction alpha1 at t=10 s. ). Additional, I have a kind of "leakage flow" where fluid leaks from the higher permeable layer into the other one.
Basically, the simulation performs as expected. However, the flow front lead lag I find is much greater than expected, and having a close look at the simulation (see Problem2.jpg) it becomes clear that the fluid does not arrive at the bottom of the lower permeable layer as it should. Since this phenomenon only affects the last layer of cells regardless how many volume elements I have in "thickness" direction, I assume that this problem is due to the applied boundary conditions.
Presently, I set the following boundary conditions:
HTML Code:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      alpha;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall
        type            zeroGradient;
    outflow
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
   inflow
      type    fixedValue;
      value   1;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
boundaryField
    wall
        type            zeroGradient;
    inflow
        type            fixedValue;
        value           3.5e4;
    outflow
        type            fixedValue;
        value           $internalField;
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall
        type            slip;
        value           uniform (0 0 0);
    inflow
        type            pressureInletUniformVelocity;
        phi             phi;
        rho             rho;
    outflow
        type            pressureInletOutletVelocity;
        phi             phi;
Do you have any idea how to change the boundary conditions in order to avoid this problem?
I have no idea what the bc "symmetry plane" does, is it of use here?
Thank you,
Natalie
Natalie2210 is offline   Reply With Quote
Old   October 10, 2013, 06:42
Hi everybody,
I think I can now state the problem differently:
Basically, in my setup as described in the previous post, I have two layers of material. The fluid flows faster through the upper material since it presents less resistance than the lower material layer due to different permeability values specified for each.
So, the fluid flows fast through the upper layer and leaks into the lower layer. This leakage flow in thickness (z-) direction is considerable and almost fills the lower layer completely. Due to this differences in velocities, I also obtain a non-constant pressure profile - basically, the pressure should drop in direction of the lower permeable layer.
The attached plot shows that this is actually the case. However, in the lower permeable layer at z=0, a nearly constant pressure profile is present. Therefore, there is no driving force to force the fluid from the top to actually the very bottom of the simulation domain, which results in the problem stated in the previous thread.
I believe that the pressure profile in thickness direction is heavily influenced by the boundary condition I pose, namely, I pose a zeroGradient boundary condition on the pressure. However, what I really want is the linear continuation of my pressure profile at the boundary.
Is there a boundary condition in OpenFoam which can do this?
Thank you for patiently reading my post,
Natalie
Old   December 2, 2013, 06:26
No one here has any thoughts on this? I'd still be interested, you know..
Setting BCs for Riverine Flows using Interfoam kflora OpenFOAM Running, Solving & CFD 38 July 27, 2022 07:51
Point BCs for Heat Transfer Problem cdm OpenFOAM 6 May 31, 2013 13:48
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 13:46
Warning 097- AB Siemens 6 November 15, 2004 05:41
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
