error with simplefoam.
Old   October 8, 2013, 16:03
Nima Samkhaniani
nimasam is on a distinguished road
it seems fine, just try for sides wall, slip BC
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 8, 2013, 16:07
izna O'connor
izna is on a distinguished road
hii
But i want my wind to go out from all 3 boundary hence i choose outflow for all 3..
izna is offline   Reply With Quote
Old   October 8, 2013, 16:10
Nima Samkhaniani
then try inletOutlet
type inletOutlet;
inletValue uniform 0;
value uniform 0;
Old   October 8, 2013, 16:12
izna O'connor
thanks Nima..
I am going to try this for the full folder of 0..
Old   October 8, 2013, 17:06
izna O'connor
hi.
with inletoutlet i achieve convergence at 313 but when i view my domain.. then complete blue colour ie zero velocity..
https://www.dropbox.com/sh/hlwk4g3bsk1zi8p/iPm_UXOZ9k
Old   November 30, 2013, 05:43
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Nima,
I'm using OF2.2.2 and am solving a laminar problem using modified buoyantBoussinesqSimpleFoam. blockMesh compiles well. But when I run it I get this error. Its the same as what Izna had. I've double checked the boundary conditions and the geometry. They seem to be fine. I do not know why this error persists
Create time
Create mesh for time = 0
Reading g
Reading thermophysical properties
Reading field T
Reading field p_rgh
Reading field U
Selecting incompressible transport model Newtonian
Creating turbulence model
Selecting RAS turbulence model laminar
Reading field alphat
Calculating field g.h
No finite volume options present
SIMPLE: convergence criteria
    field p_rgh     tolerance 0.01
    field U     tolerance 0.0001
    field T     tolerance 0.01
Starting time loop
Time = 1e-05
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  Foam::fv::gaussGrad<Foam::Vector<double> >::correctBoundaryConditions(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#4  Foam::fv::gaussGrad<Foam::Vector<double> >::calcGrad(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5  Foam::fv::gradScheme<Foam::Vector<double> >::grad(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#6  Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#7  Foam::incompressible::RASModels::laminar::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
 in "/home/srivathsan/OpenFOAM/srivathsan-2.2.2/platforms/linuxGccDPOpt/bin/buoyantBoussinesqSimpleFoamTemp"
#9  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
I have also attached my fvSolutions file and blockMeshDict file. The fields that I have are p p_rgh T U and alphat. I have removed the other fields as I have switched off turbulence. Is that ok?
Thanks in advance.blockMeshDict.txt
fvSolution.txt
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   December 2, 2013, 01:23
Srivathsan N
Judging by the error that has appeared I think its a problem in my fvSolutions file. Am I right? Also, since I've switched off turbulence I needn't include the discretization schemes for k, epsilon, omega and nut, right? Is that what is causing the error?
Update: I just tried running another solver with the same boundary condition. and I get the exact same error. Is it a generic one? I'm not able to find out what it is from the error that I get. Any help will be really helpful, 'cos I'm lost at this point.
Thanks.
Regards,
Srivaths
simplefoam stability
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H uli OpenFOAM Programming & Development 7 January 26, 2013 16:01
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 04:08
