chtMultiRegionFoam heat flux
Old   September 27, 2013, 09:08
Default chtMultiRegionFoam heat flux
sailor79 is on a distinguished road
Hi folks,
I want to simulate a block of steel which has a cooling channel (water) in it. A constant heat flux is applied on top of the block. You can see the geometry in the attached picture.
I applied the solidWallHeatFluxTemperature bc to the top. Unfortunately the heat flux at the top does not correspond to the heat flux removed by the water. Here are some values:
Heat flux density at the top: 50000 W/m²
Area at the top: 0.03 m²
--> total heat flux: 1500 W
Water velocity: 0.424 m/s
Channel diameter: 10e-3 m
Density: 997 kg/m³
cp: 4182 J/kg/K
difference in Temperature inlet - outlet: 22 K
--> removed heat flux: ~3005 W
All the faces of the block are set to zeroGradient concerning Temperature.
I checked the heat flux over the channel Wall with swak4foam:
qChannelWall
    type swakExpression;
    valueType patch;
    patchName mould_to_channel;
    verbose true;
    expression "-K*area()*snGrad(T)";
    accumulations (sum);
    region mould;
It is in the range of the applied heat flux at the top. Thermophysical properties of water are set to:
thermoType      hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<incompressible>>>>>;
mixture         water 1 18 997.05 4182 0 890.08e-6 6.127; // 25°C
Does someone have an idea what else I might check?
Thanks in advance
Michael
sailor79 is offline   Reply With Quote
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 04:27
Wall Heat Flux & Temperature Greg Perkins FLUENT 10 November 20, 2015 10:32
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
Negative Heat Flux shashank312 FLUENT 3 December 9, 2011 18:00
CFX - wall heat flux divarano CFX 2 December 4, 2006 17:14
