Lund Recycled Method for LES (flat plate)
Like Tree36Likes
Old   August 23, 2016, 02:39
Tsuyoshi Koyama
t.koyama is on a distinguished road
Dear all,
Does anyone know what the boundary conditions for velocity(U) and pressure(p) used in Joachims example ( Lund Recycled Method for LES (flat plate)) are?
t.koyama is offline   Reply With Quote
Old   August 23, 2016, 04:00
Christoph Wenzel
ChrisWe is on a distinguished road
Yes, the boundary condition for the velocity is:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1 0 0);
boundaryField
    inlet
        type            scaledMappedVelocity;
        deltaInlet      0.243;
        thetaInlet      0.028;
        Ue              1;
        nu              2e-5;
        t               2e-2;
        UMeanSpanTime   uniform (0 0 0);
        value           uniform (1 0 0);
    outlet
        type            advective;
    plate0
        type            fixedValue;
        value           uniform (0 0 0);
    plate1
        type            fixedValue;
    top0
        type            zeroGradient;
    top1
        type            zeroGradient;
    front0
        type            cyclic;
    front1
        type            cyclic;
    back0
        type            cyclic;
    back1
        type            cyclic;
    interface0
        type            cyclic;
    interface1
        type            cyclic;
and the boundary condition for the pressure is:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    plate0
        type            zeroGradient;
    plate1
        type            zeroGradient;
    top0
        type            fixedValue;
    value        uniform 0;
    top1
        type            fixedValue;
    value        uniform 0;
    front0
        type            cyclic;
    front1
        type            cyclic;
    back0
        type            cyclic;
    back1
        type            cyclic;
    interface0
        type            cyclic;
    interface1
        type            cyclic;
All the best,
Christoph
ChrisWe is offline   Reply With Quote
Old   August 23, 2016, 04:04
Tsuyoshi Koyama
Dear Christoph,
Thank you so much for your quick reply!!!
I have really been struggling to get the boundary conditions right for
this problem. I will try them right away!
Old   August 24, 2016, 23:15
Tsuyoshi Koyama
Dear Christoph,
Thank you for uploading the BC files. I tried them with my case and was able to get the problem working after some modifications.
The major problem other than the BC's was the accuracy in my solves at each time step. The lack of accuracy was creating
artificial turbulence and corrupting my solution.
Sincerely,
-Tsuyoshi Koyama
Old   October 19, 2016, 01:22
James Zh
mcshidada is on a distinguished road
Hi Foamers,
I'm really curious about this method, but unfortunately there is nothing in the dropbox link...Can anyone send me a copy of the test case to the address zfr2078@gmail.com ? Thanks in advance!!
Regards
J Zhang
mcshidada is offline   Reply With Quote
Old   October 19, 2016, 07:53
Timofey Mukha
tiam is on a distinguished road
Dear all,
You might be interested in looking at a python package I have written, it allows to rescale sampled velocity fields using the Lund's rescaling procedure and save them in a format readable by OpenFOAM.
There is a User guide available here:
http://eddylicious.readthedocs.io/
And the code is here
https://github.com/timofeymukha/eddylicious
cedric_duprat and huangfei like this.
tiam is offline   Reply With Quote
Old   November 7, 2016, 23:10
Wenkun Zhao
Eric Brant is on a distinguished road
Hi Joachim,
I am very interested in Lund's recycling methods but unfortunately it is used for incompressible flows. So I studied recaling-recycling method and extend it for compressible flows just by adding Van Driest velocity to scaledMappedVelocity and creating scaledMappedTemperature. But I have encountered a problem: I run these boundary conditions well using single processor but failed in parallel calculating. By the way, have you ever calculated in parallel using your code? I just modified your code by adding some extra codes and I think it doesn't affect parallel process. Here's my attached codes for compressible flows.
P.S. my OpenFOAM version is 2.4.0
Eric Brant is offline   Reply With Quote
Old   November 8, 2016, 10:38
Wenkun Zhao
Originally Posted by cfd.with.openfoam View Post
In this rescaling technique it seems that I would still need a mean profile for different variables at the inlet of my domain. After that I would need to perturb the domain e.g using the perturbU utility. After following these steps I should expect a self sustaining turbulent BL. Is that correct?
Hi All,
I wonder where perturbU utility is, there's no such utility in offical version of OpenFOAM, and I don't know how to calculate the initial field for following LES calculation. Any suggestions?
Best,
Eric
Old   November 9, 2016, 14:23
Mahdi Hosseinali
anishtain4 is on a distinguished road
That utility has been taken out of the standard version (not sure why?) but there's a link in the wiki explaining how to add it back:
https://openfoamwiki.net/index.php/Contrib/perturbU
it's very simple and straightforward.
anishtain4 is offline   Reply With Quote
Old   November 10, 2016, 03:34
Wenkun Zhao
Hi Mahdi,
Thanks for your quick response, I have download perturbU and successfully compiled it on OpenFOAM-2.4.0. I opened the perturbU.C and after scanning the code I know that
if (setBulk)
is to set the mean velocity profile and
if (perturb)
is to set perturbation. To see how the perturbation is generated. I found it in the following codes:
 if (perturb)
            // streak streamwise velocity
            U[celli][streamDir] +=
                (utau * duplus/2.0) * (yplus/40.0)
                * Foam::exp(-sigma * Foam::sqr(yplus) + 0.5)
                * Foam::cos(betaPlus*zplus)*deviation;
            // streak spanwise perturbation
            U[celli][spanDir] =
                epsilon
              * Foam::sin(alphaPlus*xplus)
              * yplus
              * Foam::exp(-sigma*Foam::sqr(yplus))
              * deviation;
I don't know why use these formula to set perturbation.
Is there any perturbation theory or related references?
Best
Old   November 14, 2016, 14:24
Mahdi Hosseinali
Random perturbations will be easily damped out if they lack a spatial correlation. Also to initialize don't use turbulent profile, use laminar.
Those streaks are based on a paper by Schoppa and Hussain:
https://www.researchgate.net/publica...all_turbulence
They are the best way to excite the near wall fluctuations and transient into turbulent.
Old   April 13, 2018, 03:54
Wang Yifan
YI Fan is on a distinguished road
Originally Posted by Eric Brant View Post
Hi Joachim,
Hi Eric,
I tried your BCs. Add "mpp.distribute(URecycled);" in scaledMappedTemperatureFixedValueFvPatchField.C, and it will work fine in parallel calculating.
Of course, you may have already solved this problem.
By the way, which paper are your BCs based on?And how do you set your boundary condition for field p?
Best
Yifan
YI Fan is offline   Reply With Quote
Old   December 3, 2018, 05:52
Jianrui Zeng
calf.Z is on a distinguished road
I need this BC for my DNS simulation, can anyone share the code and additional files to me? My email is 32420171152101@stu.xmu.edu.cn
Thank you very much.
calf.Z is offline   Reply With Quote
Old   January 14, 2019, 16:17
Yong Wang
windstriver is on a distinguished road
Could you send me a copy of your case files? It would be great help to setup a base case for comparison of synthetic inflow generation method. My email is y.wang@ttu.edu. Thanks a lot.
windstriver is offline   Reply With Quote
Old   August 19, 2019, 07:05
Arrow Joachim's Code
  #75
Oguzhan
heisenmech is on a distinguished road
Hi all,
Can anyone please send me the Joachim's code? I did bit of search but couldn't find it anywhere online. Email: oguzhanmurat06@gmail.com
Thanks.
heisenmech is offline   Reply With Quote
Old   December 16, 2019, 10:49
Shawn
kennymhx is on a distinguished road
Dear all
I'm really curious about this method, but unfortunately there is nothing in the dropbox link...Can anyone send me a copy of the test case to the address shawnhu94@gmail.com ? Thanks in advance!
kennymhx is offline   Reply With Quote
Old   December 16, 2019, 10:58
Shawn
Originally Posted by Loey View Post
Hi, Vishwakarma
Thank you for your kindness. I have got a copy, but I have a question to ask: How is the initial internalField generated?
Loey
Dear Loey
Old   January 27, 2022, 11:31
Default Run runLundRescaling --config=rescalingConfigBot
  #78
Naira is on a distinguished road
Hi Foamers
Can somebody please tell me how to proceed with this runLundRescaling --config=rescalingConfigBot
as mentioned in https://github.com/timofeymukha/eddy..._lund.rst#id15
I am unable to run this command.
Naira is offline   Reply With Quote
Old   January 27, 2022, 12:15
Timofey Mukha
Hi. So, did you install eddylicious? The command is part of the package.
Old   June 15, 2022, 04:11
Tingkai Dai
jayddkt is on a distinguished road
I'm really interested in the Lund's method,but the test case in the dropbox doesn't exist. Can anyone share the files to me? My email is jayddkt@sjtu.edu.cn
Thanks a lot.
jayddkt is offline   Reply With Quote
les lund recycled method
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Low Reynolds Number Flow over a Flat Plate Go FLUENT 4 August 28, 2013 06:19
different boundary conditions for flat plate easyRider Main CFD Forum 0 March 20, 2012 09:40
Conjugate heat transfer for film-cooled flat plate Michele FLUENT 0 July 3, 2006 09:42
flat plate boundary layer data Ekachai Juntasaro Main CFD Forum 3 March 14, 2001 00:18
