kOmegaSST gets the results stalled too early
Old   September 23, 2013, 00:22
Default kOmegaSST over-predict the CL when stall happens
Jay
Juansheng is on a distinguished road
Hi all,
Thanks for the wonderful CFD software first of all. I'd admit I just learned OpenFOAM just for a week. I'm working on simulating an oscillating airfoil using pimpleDyMFoam solver with kOmegaSST turbulence model. The oscillating function is: 2.1 + 8.2*sin(193*t), Reynold number is about 4e6. So it should be a light stall condition. But the results show that CL seems getting stalled very early. I packed the 0/ directories, and the CL plot as well. I set the alpha to steady 2.1 degree, CL(0.15~0.2) seems not bad comparing with experiment result. Also I tried different K or omega, the data changed a bit but still stay far from the correct results. Hope experts give me some suggestions. Thanks again.
PS, I got and built the OpenFOAM from github, which would be the latest svn afaik.
EDIT: Even with deep stall condition, I also got the full circle for CL. I did something totally wrong. The delay of CL does not indicate the dynamic stall phenomenon. Weird.
Juansheng is offline   Reply With Quote
Old   October 6, 2013, 06:01
Jay
OK, the main problem is that I set the oscillating frequency too high (193 as posted before). After lowering that value according to reduced frequency, CL under this light stall condition was predicted correctly (see #1), although there still a bit difference between OF and experimental data.
On the deep dynamic stall, OF tends to over-predict the CL when the stall happens (#2). Is it necessary to change the turbulence model? Hope someone can give me a hint. Thanks.
EDIT: After fixing dynamic viscosity and k and omega for external flows, I got a better circle. But still the CL when stall begins was over-predicted too much. see #3 image.
Best,
Jay
airfoil, komegasst, oscillating, pimpledymfoam
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
Oscillating Airfoil Poor Results at High k (reduced frequency) dancfd OpenFOAM Running, Solving & CFD 3 November 4, 2013 09:32
komegaSST model stix OpenFOAM Running, Solving & CFD 5 March 4, 2013 09:30
flatplate Turbulent BL flow, OF, kOmegaSST model nikesh OpenFOAM Post-Processing 0 October 16, 2012 05:43
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
