Modelling Heat Transfer of a Lamp
Old   September 22, 2013, 18:38
Default Modelling Heat Transfer of a Lamp
orbisvicis is on a distinguished road
I've created a lampshade suitable for 3D printing and I would like to determine the maximum wattage incandescent bulb which will not surpass the material's safe operating temperature. (I've also modelling the entire lamp)
I've read the first two chapters of the openFOAM user guide, and I feel pretty confident about converting the blender model to graded cells and specifying boundaries, however I'm not sure which model/solver I should use. I could use some help with the "big picture" approach. These are the specifics I would like to model:
  • Which models/solvers do I use to simulate radiation (lightbulb->shade), convection (bulb->air, air->shade, shade->air), and conduction (bulb->air, air->shade, shade->shade, shade->air) and hook these all together?
  • Do I need any special handling of infrared - incandescent light bulbs emit lots of infrared?
  • Is convection turbulent?
orbisvicis is offline   Reply With Quote
Old   September 23, 2013, 16:59
Jace
zhengzh5 is on a distinguished road
the solver of interest here should be the chtMultiRegionFoam, which is basically a solver for conjugate heat transfer involving multiple regions. (in your case, the bulb, air and the shades). you can turn on the radiation model when running chtMultiRegionFoam, and there's few choices for radiation models, of which one is the view factor approach. I haven't dug too deep into it yet, but that should give you a starting point.
I believe it handles turbulent flows, check out the tutorial case in foam's chtMultiRegionFoam directory for detail of case setup.
Hope that helps!
zhengzh5 is offline   Reply With Quote
bulb, heat flow, heat transfer, light, thermal
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
Modelling Heat transfer between stack and gas in Thermoacoustic Chirag2302 FLUENT 0 April 24, 2012 02:14
heat transfer modelling morteza08 Main CFD Forum 2 October 15, 2010 14:45
Modelling combustion and heat transfer Tudor FLUENT 4 May 9, 2005 08:02
