Radial Equilibrium pressure BC
Old   September 18, 2013, 14:19
Default Radial Equilibrium pressure BC
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi All,
I am looking for a small information and help, I have done many simulation with MRFSimpleFoam.
now I am facing small issue for the pressure boundary condition.
I was using 0/p:
inlet zeroGradient;
outlet fixedValue;
value 0;
I plotted the pressure curve close to the surface (see fig)
computational domain is -1.5 m inlet and 6 m of outlet (from the fan)
the attached pressure curve looks fine upto 5.5m but after that its started decreasing due to the given outlet boundary condition.
I am expecting the curve to be reasonable straight line, is there any other outlet BC's to produce such curve?
please help me with some sort of information.
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   September 18, 2013, 14:39
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good evening Sivakumar
Could you also please post your velocity boundary conditions and your fvSchemes file?
I have seen something similar in the past and that was related to the choice of time integration scheme, but I cannot find the thread. The conclusion was that it helped to using Euler.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 18, 2013, 14:55
sivakumar selvaraju
Hi Niels, Good evening thanks for your quick reply,
0/U
inlet flowRateInletVelocity;
outlet zeroGradient;
and the fvSchemes are as follows
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) leastSquares;
grad(omega) Gauss linear;
grad(epsilon) Gauss linear;
grad(U) Gauss linear;
grad(k) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
div(phi,epsilon) Gauss upwind ;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear limited 0.7;
laplacian((1|A(U)),p) Gauss linear limited 1;
laplacian(DkEff,k) Gauss linear limited 0.7;
laplacian(DepsilonEff,epsilon) Gauss linear limited 0.5;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default limited 0.5;
fluxRequired
default no;
p ;
Thanks,
Sivakumar
Old   September 18, 2013, 15:06
ngj
Hi
I am sorry, but nothing come to my mind.
Good luck,
Niels
Old   September 18, 2013, 15:21
sivakumar selvaraju
Hi Niels,
Its fine thanks for your time, if you dont mind can you please give me the thread link.
Thanks,
Sivakumar
Old   September 25, 2013, 10:40
sivakumar selvaraju
hi there,
I am sorry, Euler time integration method is not solving the problem.
Thanks,
Sivakumar
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Fluent natural ventilation pressure boundary condition pierresandre FLUENT 24 November 8, 2011 15:32
Setting Pressure outlet boundary for simulation of Radial impeller Mukund Pondkule Main CFD Forum 1 April 5, 2011 10:24
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
use of radial equilibrium press. in 2 phase flow James Willie FLUENT 0 May 2, 2005 12:26
