Howto use scalarCodedSource in fvOptions
Like Tree37Likes
Old   March 31, 2015, 18:07
EnricoA is on a distinguished road
Hello alexeym,
I am trying to implement a source term for turbulent dissipation in a simulation using the standard k-epsilon model following your explanation about the scalarCodedSource. I ended up with this fvOptions file (where there is also a source for the momentum equation):
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
momentumSource
    type            vectorSemiImplicitSource;
    selectionMode   cellZone;
    cellZone        disk;
    active          true;
    vectorSemiImplicitSourceCoeffs
        volumeMode      absolute;
        injectionRateSuSp
            U           ((0 0 -180e3) 0);
dissipationSource
    type            scalarCodedSource;
    cellZone        disk;
    active          true;
    scalarCodedSourceCoeffs
        fieldNames      (epsilon);
        redirectType    sourceTime;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
            const Time& time = mesh().time();
            const scalarField& V = mesh_.V();
            const vectorField& C = mesh_.C();
            const scalarField& nut_ = nut();
            const vectorField& U_ = U();
            const scalarField& k_ = k();
            const scalarField& Pt = nut_*2*magSqr(symm(fvc::grad(U_)));
            scalarField& epsilonSource = eqn.source();
            forAll(C, i)
                epsilonSource[i] -= 0.37*Pt[i]*Pt[i]/k_[i]*V[i];
            Pout << "***codeAddSup***" << endl;
        codeSetValue
                Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
Apparently there are some mistakes in my file which I cannot find, because when I run the simulation the output is:
--> FOAM Warning :
From function void option::checkApplied() const
in file fvOptions/fvOption.C at line 368
Source dissipationSource defined for field epsilon but never used
Do you have any advises to give me?
Thanks
LidaSa likes this.
EnricoA is offline   Reply With Quote
Old   April 1, 2015, 02:50
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
My advice: implement your own turbulence model I.e. you take k-epsilon family model, copy it, rename it, add your code.
There are certain conditions for fvOptions to work, see, for example, UEqn.H of pimpleFoam:
tmp<fvVectorMatrix> UEqn
    fvm::ddt(U)
  + fvm::div(phi, U)
  + turbulence->divDevReff(U)
    fvOptions(U)
UEqn().relax();
fvOptions.constrain(UEqn());
See all these calls to fvOptions. Now if you look at kEpsilon.C, there are no such calls.
During last workshop there was an idea of implementation of turbulence models, which use fvOptions framework. I do not know if there is any progress, for me it is still on TODO list.
alexeym is offline   Reply With Quote
Old   April 28, 2015, 06:36
Default fvOptions heatsource in chtmultiregionsimpleFoam case in openfoam2.3.x
  #23
Sandeep Rapol
sandeeprapol is on a distinguished road
Hello everyone
I am implementing volumetric heat source in chtmultiregionsimplefoam with help of fvoptions files
in that "duration ....." and " h(.... 0)" so my problem is
1) how to convert 200 W source into enthalpy h(... 0) with help of "duration ...." in sec
2) in that "fvOptions" file "duration..." so which time put here in duration
sandeeprapol is offline   Reply With Quote
Old   April 28, 2015, 06:49
Alex
zfaraday will become famous soon enough
Originally Posted by sandeeprapol View Post
Hello everyone
Hello Sandeep!
1) You don't need to convert nothing into nothing. For the case of using chtMultiRegionSimpleFoam you just have to put the thermal power value into the first place within the brackets, like that:
energySource
    type            scalarSemiImplicitSource;
    active          true;
    selectionMode   all;
    scalarSemiImplicitSourceCoeffs
        volumeMode      absolute;//specific;//
        injectionRateSuSp
            h           (q 0); //   q in [W]; or in [W/m³] if you use specific mode
2) Never used the duration field (I don't even know wether it exist) as you can see in the piece of code above.
Hope it helps.
Best regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   April 28, 2015, 07:03
Alexey Matveichev
@faraday
In fact the field comes from base abstract fvOption and defines duration of time the option is active:
inline bool Foam::fv::option::inTimeLimits(const scalar time) const
    return
        (timeStart_ < 0)
            (mesh_.time().value() >= timeStart_)
         && (mesh_.time().value() <= (timeStart_ + duration_))
bool Foam::fv::option::isActive()
    if (active_ && inTimeLimits(mesh_.time().value()))
        return true;
    else
        return false;
zfaraday likes this.
Old   April 28, 2015, 07:10
Alex
Thanks for the clarification Alexey! I didn't remember that because I never had to specify the duration of the source.
Everything must be clear now for @Sandeep.
Old   April 28, 2015, 08:42
  #27
Sandeep Rapol
hello alex,
thank you for the replay , I used that syntax in fvOptions file but result showing no heat generation, it shows constant temperature
when I use my fvOptins that showing heat generation it include "duration....." of time
heatSource
active on;
timeStart 0.;
duration 1e3;
selectionMode cellSet;
cellSet IC1;
// volumeMode absolute; // Values are given as <quantity>
volumeMode specific; // Values are given as <quantity>/m3
injectionRateSuSp // Semi-implicit source term S(x) = S_u + S_p x
h (200000 0);
am trying to implement 200 W/m3 volumetric heat generating source for circuit board cooling
raj kumar saini likes this.
Old   April 28, 2015, 09:09
Alex
Well, I don't understand why my specification is not working. As per what I see you are using a cellSet as a selection mode, while I sellect all cells belonging to one region. If you just copypasted all my specification of course it's not going to work...
Another point I don't get is why you are setting a generation of 200000 when you say your generation is supposed to be of 200 W/m2... If you give a higher value than the one you need, obviously the effect will be more visual and bigger...
Regards,
Alex
Ps: excuse me if I wrote something wrong, I'm writing from my phone
Old   April 29, 2015, 08:01
Sandeep Rapol
hello alex,
you are on the right way you see in src/fvOptios/lninclude/fvOptionListTemplates.C
at line no 135
ds = rho.dimensions()*fld.dimensions()/dimTime*dimVolume
rho * h *1/time * vol
kg/m3 * j/kg * m3 / sec
j/s
W
so here is dimTime in sec plese tell me how to implement 200 W/m3 heat generating source
altinel likes this.
Old   April 29, 2015, 08:47
Alex
check this out!
Old   April 30, 2015, 07:25
Sandeep Rapol
hello alex
thank you for your humble reolay
in fvoptions
what is "absolute" and "specific"
if my heat generating element is 200 W having dimension 0.2m*0.01m*0.05m
1) if I consider "absolute" then total element given value is 200 W is this correct or not?
2) if I consider "specific" then total element each cell point given value is 200 W is this correct or not?
Old   April 30, 2015, 08:40
Alex
Dear Sandeep,
the meaning of "absolute" and "specific" is given behind "//". Then, if you consider "absolute" mode you just have to give the constant source term a value of 200. On the other hand, if you prefer to use "specific" mode you have to use a value of 200/(0.2*0.01*0.05).
That's all!
Best regards,
Alex
Old   May 4, 2015, 05:49
Sandeep Rapol
thank you alex,
which parameter analyze in post processing.I thought that only temp of oullet, & velocity is analyze in chtmultiregionSimpleFoam and chtmultiRegionFoam please suggest me
Old   May 11, 2015, 15:08
I would like to follow up my previous post regarding the implementation of a source term for the turbulent dissipation rate with scalarCodedSource.
I eventually implemented my own turbulence model of the k-epsilon family. This is the main modification which takes into account the possible source term:
// Dissipation equation
tmp<fvScalarMatrix> epsEqn
    fvm::ddt(epsilon_)
  + fvm::div(phi_, epsilon_)
  - fvm::laplacian(DepsilonEff(), epsilon_)
    C1_*G*epsilon_/k_
  - fvm::Sp(C2_*epsilon_/k_, epsilon_)
  + fvOptions(epsilon_)
epsEqn().relax();
fvOptions.constrain(epsEqn());
epsEqn().boundaryManipulate(epsilon_.boundaryField());
solve(epsEqn);
fvOptions.correct(epsilon_);
bound(epsilon_, epsilonMin_);
Then I was trying to add a source of the following form in a particular region:
S = 0.37 G^2 / k
where G is the the generation of turbulent kinetic energy computed in the sandard k-epsilon model and k is the turbulent kinetic energy. In order to do this, I added the following piece of code to fvOptions:
dissipationSource
    cellZone        diss;
    active          true;
        codeInclude
            #include "fvCFD.H"
        codeCorrect
        codeAddSup
            const volScalarField& nut = mesh().lookupObject<volScalarField>("nut");
            const volVectorField& U = mesh().lookupObject<volVectorField>("U");
            const volScalarField& k = mesh().lookupObject<volScalarField>("k");
            const volScalarField& G = nut*2*magSqr(symm(fvc::grad(U))); // as computed in the k-epsilon model
            forAll(C,i)
                epsilonSource[i] -= 0.37*G[i]*G[i]/k[i];
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
When I run a simulation, the compilation of the dynamic library doesn't give errors but apparently there is something wrong with my implementation, since the results that I get don't match with the expected one.
Can you see any errors in the code?
Thanks
Old   September 8, 2016, 15:40
Nima Samkhaniani
nimasam is on a distinguished road
Dear Alex
How to set multiple discrete heat sources using scalarSemiImplicitSource ?
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 3, 2017, 12:24
Default what for solver using EEqn.C?
  #36
M. C.
student666 is on a distinguished road
active true;
selectionMode all;
injectionRateSuSp
just a clarification for buoyantSimpleFoam.
This solver uses EEqn.C file, so you have to specify the thermal model.
In case you set the following dict for thermophysicalProperties
        type heRhoThermo;
        mixture pureMixture;
        transport const;
        thermo hConst;
        equationOfState perfectGas;
        specie specie;
        energy sensibleEnthalpy;
q parameter (specific) is equal to Watt only if you consider a fluid with Cp = 1kJ/(kg*K) and rho = 1 kg/m^3 as for Q= rho cp * T(1Kelvin)/1sec = 1W/m3 as h = Cp*T(1Kelvin)/1sec = 1W/kg
but if you consider a fluid with Cp = 4.186kJ/(kg*K) and rho = 1000 kg/m3, if you want to have 1W/m3 you have to set h value (q parameter [specific] ) equal to 0,000000239
 q = Q = rho*Cp*T/t ==> 1/1000/4186
is it correct?
student666 is offline   Reply With Quote
Old   January 4, 2017, 18:38
M. C.
I performed this simple test case.
3D simulation.
All patches have been set to "walls"(T=293K), but patch named "fondo" has been set to zeroGradient for T.
cellZone "c0" , at the bottom (coord z=0), has 500W power source.
laminar.
simulation performed with openFoam v4.1
run
blockMesh
topoSet
renumberMesh -overwrite
buoyantPimpleFoam > log.1
when steadyness is reached, stop running and
wallHeatFlux
you may see dissipation through patch "pareti" equal to heat (absolute) source 500W in fvOptions.
Time = 2.554868161131
Selecting thermodynamics package
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
Selecting turbulence model type laminar
Wall heat fluxes [W]
pareti
    convective: -497.79226
    radiative:  -0
    total:      -497.79226
fondo
    convective: 0
    radiative:  -0
    total:      0
Time = 2.9167083871732
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
pareti
    convective: -498.87276
    radiative:  -0
    total:      -498.87276
fondo
    convective: 0
    radiative:  -0
    total:      0
Time = 3.27661601896623
    type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
pareti
    convective: -499.42118
    radiative:  -0
    total:      -499.42118
fondo
    convective: 0
    radiative:  -0
    total:      0
End
Hope this can clarify any further doubt...mine too.
Regards.
Old   February 14, 2017, 03:37
ChrisBa is on a distinguished road
I'm trying to implement a volumetric source with scalarCodedSource.
At the surface the equation: q=q0 * e^(re^2/r^2)
In the depth the value q0 is described with functions.
I'm using Openfoam 4.1 and the solver buoyantBoussinesqSimpleFoam.
After calling the function I get this:
Creating finite volume options from "constant/fvOptions"
--> FOAM FATAL ERROR:
Attempt to return primitive entry ITstream : /home/cfd/OpenFOAM/cfd-4.1/run/elektronen/constant/fvOptions.heatSource.scalarCodedSourceCoeffs.codeInclude, line 31, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD
    primitiveEntry 'codeInclude' comprises
        on line 31 the verbatim string "\
 as a sub-dictionary
    From function virtual const Foam::dictionary& Foam::primitiveEntry::dict() const
    in file db/dictionary/primitiveEntry/primitiveEntry.C at line 189.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::primitiveEntry::dict() const at primitiveEntry.C:?
#3  Foam::dictionary::substituteScopedKeyword(Foam::word const&) at ??:?
#4  Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:?
#5  Foam::dictionary::read(Foam::Istream&, bool) at ??:?
#6  Foam::dictionary::dictionary(Foam::fileName const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#7  Foam::dictionaryEntry::dictionaryEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#8  Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:?
#9  Foam::dictionary::read(Foam::Istream&, bool) at ??:?
#10  Foam::dictionary::dictionary(Foam::fileName const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#11  Foam::dictionaryEntry::dictionaryEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#12  Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:?
#13  Foam::dictionary::read(Foam::Istream&, bool) at ??:?
#14  Foam::dictionary::dictionary(Foam::fileName const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#15  Foam::dictionaryEntry::dictionaryEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:?
#16  Foam::entry::New(Foam::dictionary&, Foam::Istream&) at ??:?
#17  Foam::dictionary::read(Foam::Istream&, bool) at ??:?
#18  Foam::operator>>(Foam::Istream&, Foam::dictionary&) at ??:?
#19  Foam::IOdictionary::readFile(bool) at ??:?
#20  Foam::IOdictionary::IOdictionary(Foam::IOobject const&) at ??:?
#21  Foam::fv::options::options(Foam::fvMesh const&) at ??:?
#22  Foam::fv::options::New(Foam::fvMesh const&) at ??:?
#23  ? at ??:?
#24  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#25  ? at ??:?
Abgebrochen (Speicherabzug geschrieben)
My fvOption-file looks like this:
heatSource
    active          true;
    selectionMode   all;
        fieldNames      (T);
        name            sourceTime;
        codeInclude
        codeCorrect
        codeAddSup
            scalarField& TSource = eqn.source();
            //Values for checking the equations
            const scalar power = 1000;
            const scalar Radius = 0.5;
            const scalar rho = 1000;
            const scalar Cp = 4.19;
            const scalar xCenter = 3;
            const scalar yCenter = 0.01;
            const scalar zCenter = 2;
            // Equations
            // -Face centers
            const List<point>& cf = p.Cf();
            const scalar xCF = cf[c][0];
            const scalar XF = xCenter - xCF;
            const scalar check+ = xCenter + Radius;
            const scalar check- = xCenter - Radius;
            if ((xCF < check+) && (xCF > check-))
                const scalar r2 = XF * XF;
                const scalar re2 = Radius * Radius;
                const scalar factor = r2/re2;
                const scalar pre = exp(factor);
                const scalar qfa_ [c] = power * exp;
                const scalar TzuF_ [c] = (1/(rho*Cp))*qfa
            else
                const scalar qfa_ [c] = 0;
            // -Depth centers or cell centers
            TSource -= Tzuf;
        codeSetValue
        code
           $codeInclude
           $codeCorrect
           $codeAddSup
           $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
Maybe somebody can help me.
regards
Chris
ChrisBa is offline   Reply With Quote
Old   February 14, 2017, 05:53
hannes
hanness is on a distinguished road
Hi Chris,
I'm not too much into the scalarCodedSource fvOptions but just by looking at the error message it tells you that on line 31 of your code something is going wrong. More precisely it is in the section codeInclude (I suppose that is line 31 when looking at the entiere fvOptions file including its header.
This section supposedly must be filled and cannot be left blank. As I'm not familiar with this tool I can't help you any further but maybe it helps.
Regards
Hannes
hanness is offline   Reply With Quote
Old   February 14, 2017, 06:42
Thanks for your reply.
I look into this.
fvoptions, heat source, scalarcodedsource
OpenFoam 2.2 fvOptions temperature limits fredo490 OpenFOAM Running, Solving & CFD 12 January 17, 2020 00:59
Building a solver with fixedTemperatureConstraint using fvOptions Fluido OpenFOAM Programming & Development 9 February 15, 2018 01:30
How to set fvOptions yurifrey OpenFOAM Pre-Processing 5 February 22, 2016 19:14
[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions) Tobi OpenFOAM Community Contributions 0 May 23, 2013 15:53
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 09:54
