How can I use absoluteEnthalpy in thermo type in2.2.1 |
September 15, 2013, 11:02 |
赵庆良
Rep Power: 13 |
Dear Foamers:
Do some Foamers want to use absoluteEnthalpy in OF2.2.1? I want use the thermo type as the following: thermoType { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy absoluteEnthalpy; equationOfState perfectGas; specie specie; } but class hePsiThermo only have "sensibleEnthalpy" insteadingof "absoluteEnthalpy".In 2.2.1,only when I use heheuPsiThermo,can I use "absoluteEnthalpy".So I have to according to class heheuPsiThermo to add "absoluteEnthalpy" in class hePsiThermo .However,when I run my case,the error showed me that there no change with "Valid psiThermo types ".In other word ,my modifies did not work.the file I modified is "thermophysicalModels/reactionThermo/psiReactionThermos.C"I just add the following code: makeReactionThermo ( PsiThermo, PsiReactionThermo, hePsiThermo, reactingMixture, sutherland, absoluteEnthalpy, janafThermo, perfectGas, specie; ) and #include "absoluteEntalpy.H" to psiReactionThermos.C.As you know ,it did not work.could you tell me how to modify psiReactionThermos.C to make my difined thermo type : { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy absoluteEnthalpy; equationOfState perfectGas; specie specie; }to be useful? Or can I build myThermo library that include thermotype what I want to use?Please someone could give some advise! Please!here is my new thermotype librarymyThermo.zip Last edited by zqlhzx; September 15, 2013 at 21:18. |
September 15, 2013, 21:36 |
赵庆良
Rep Power: 13 |
my owner solver do not solver transport(specise) equation,I have to use absoluteEnthalpy.Are not there Foamer using absoluteEnthalpy in 2.2.1?
September 28, 2013, 06:56 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings zqlhzx,
I saw that you've asked this question on several threads and gotten some answers on them:
echo $FOAM_SRC/thermophysicalModels/reactionThermo Bruno
October 13, 2013, 07:06 |
Bruno Santos
Rep Power: 128 |
Hi zqlhzx,
Attached is your library with a very minor modification, namely in the "Make/options" file. I ran: Code:
wclean libso wmake libso Therefore my questions are as follows:
Bruno
October 15, 2013, 09:46 |
#5 | |||
赵庆良
Rep Power: 13 |
Dear wyldckat:
Thank you for your replies! Quote:
HTML Code:
http://pan.baidu.com/share/home?uk=3977527442#category/type=0 |
interFoam/kOmegaSST tank filling with printStackError/Mules | simpomann | OpenFOAM Running, Solving & CFD | 3 | February 17, 2014 18:06 |
Temperature Issue in OpenFOAM-2.2.0 | prasant | OpenFOAM | 0 | March 12, 2013 08:17 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
