Running in parallel with a machine that doesn't have OpenFOAM
Old   September 12, 2013, 14:56
Default Running in parallel with a machine that doesn't have OpenFOAM
Jamal
aujamal20 is an unknown quantity at this point
I am running openfoam simulation in parallel on a machine using 4 out of 12 processors and thats working nice. Now I just get an other server without any openfoam installation on it.
Now I want to run the same simulation on two machines (servers) one with openfoam installation and the other one without openfoam installation using 4 processors from each machine.... can i do this or not and if i can, then please let me know....
thanks.
aujamal20 is offline   Reply With Quote
Old   September 14, 2013, 11:08
Retired Super Moderator
Bruno Santos
Greetings Jamal,
Technically a parallel application can only run if the respective software is somehow provided to all of the machines that will be using it. In addition, you better make sure that both machines are running the same architecture, or at least in the lower common architecture, namely both should run in 64 bit or 32 bit.
So, there are two possible solutions:
  1. You install OpenFOAM on the other machine as well, in the same way and/or path. This way you don't loose much performance on the start-up, since all binaries are already present in both machines.
  2. Or you share the installation folder on the first machine to the other machine, such as using NFS.
Best regards,
Bruno
OpenFoam Parallel running shipman OpenFOAM Running, Solving & CFD 3 August 17, 2013 11:50
OpenFOAM doesn't run in parallel callumso OpenFOAM Running, Solving & CFD 0 July 11, 2013 13:17
Problem in Running OpenFoam in Parallel himanshu28 OpenFOAM Running, Solving & CFD 1 July 11, 2013 10:19
Problem running a parallel fluent job on local machine via mpd highhopes FLUENT 0 March 3, 2011 06:07
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
