September 14, 2013, 05:28 |
Error DURING pisoFoam execution
Luca
Rep Power: 13 |
Hi everybody,
I'm running a flow inside a channel with a LES turbulence model with pisoFoam using mpirun. The simulation starts finely, the courant number is below 1 and the residuals are small enough, but then, suddenly, the simulation crashes. Here are the logs files... pisoFoam log (last iterations) Code:
Time = 0.179 Courant Number mean: 0.103331 max: 0.753686 DILUPBiCG: Solving for Ux, Initial residual = 0.00045336, Final residual = 2.92708e-06, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00204474, Final residual = 3.11798e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.00155674, Final residual = 4.13525e-06, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00324421, Final residual = 0.00011122, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000283797, Final residual = 1.25329e-05, No Iterations 5 time step continuity errors : sum local = 4.49319e-10, global = 2.29015e-13, cumulative = -1.67519e-09 GAMG: Solving for p, Initial residual = 0.000215089, Final residual = 8.163e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 2.02541e-05, Final residual = 8.09815e-07, No Iterations 6 time step continuity errors : sum local = 2.90254e-11, global = 1.42406e-14, cumulative = -1.67517e-09 ExecutionTime = 1290.76 s ClockTime = 1302 s Time = 0.18 Courant Number mean: 0.103334 max: 0.753239 DILUPBiCG: Solving for Ux, Initial residual = 0.00045237, Final residual = 2.91376e-06, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00203801, Final residual = 3.10315e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.00155273, Final residual = 4.33455e-06, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00323168, Final residual = 0.000110029, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000279401, Final residual = 1.23872e-05, No Iterations 5 time step continuity errors : sum local = 4.4384e-10, global = 2.2645e-13, cumulative = -1.67495e-09 GAMG: Solving for p, Initial residual = 0.000214297, Final residual = 8.1158e-06, No Iterations 3 GAMG: Solving for p, Initial residual = 2.00669e-05, Final residual = 8.06735e-07, No Iterations 6 time step continuity errors : sum local = 2.88982e-11, global = 1.08022e-14, cumulative = -1.67494e-09 Code:
[29] [29] [29] --> FOAM FATAL IO ERROR: [29] error in IOstream "/eurora/home/userexternal/lamerio0/driverRegion_run/processor29/0.18/U_0" for operation Ostream& operator<<(Ostream&, const Scalar&) [29] [29] file: /eurora/home/userexternal/lamerio0/driverRegion_run/processor29/0.18/U_0 at line 99612. [29] [29] From function IOstream::check(const char*) const [29] in file db/IOstreams/IOstreams/IOstream.C at line 99. [29] FOAM parallel run exiting I ran the simulation twice thinking of a memory error or something not related to OF, but both the simulations gave the error at t=0.18. So I think it's something related to it. I have totally no idea of what is going on. Does anyone can help me? Thank you very much, bye |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 10:12 |
pisoFoam, pimpleFoam - Fluent user's questions | RodriguezFatz | OpenFOAM Running, Solving & CFD | 0 | September 4, 2013 05:26 |
pisoFoam : error floating point | Dbutant | OpenFOAM Running, Solving & CFD | 10 | October 9, 2012 10:45 |
parallel execution not starting | gfilip | OpenFOAM Running, Solving & CFD | 2 | November 3, 2011 09:31 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 18:18 |
