Implementation of 2nd order upwind scheme
Old   September 12, 2013, 19:36
Default Implementation of 2nd order upwind scheme
Jason Pearl
jaason is on a distinguished road
Hi FOAMers,
I want to implement a 2nd order upwind scheme. However i get the error message below whenever I try to use a scheme like QUICK or linearUpwind for my InterpolationSchemes, gradSchemes or my LaplacianSchemes. I can only implement a second order upwind scheme in the divergence section. My fvSchemes file is pasted below
attempt to read beyond EOF
file: /home/owner/OpenFOAM/owner-2.2.0/run/Thesis/sonicFoam/Sept12/system/fvSchemes.interpolationSchemes.interpolate(U_0) at line 59.
    From function ITstream::read(token&)
    in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
ddtSchemes
    default         Euler;
gradSchemes
    default         none;
    grad(U)        Gauss upwind phi;
    grad(p)        Gauss upwind phi;
    grad(e)        Gauss upwind phi;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind phi;
    div(phid,p)     Gauss upwind phi;
    div(phi,e)      Gauss upwind phi;
    div(phi,K)      Gauss upwind phi;
    div(phiv,p)     Gauss upwind phi;
    div((muEff*dev2(T(grad(U))))) Gauss linear 1;
laplacianSchemes
    default                 none;
    laplacian(muEff,U)        Gauss linear corrected;
    laplacian(alphaEff,e)    Gauss linear corrected;
    laplacian(Dp,p)        Gauss linear corrected;
    default                         none;
    interpolate(rho)                 upwind phi;
    interpolate(rho_0)                 upwind phi;
    interpolate((((1|A(U))*rho_0)*U_0))        upwind phi;
    interpolate(HbyA)                upwind phi;
    interpolate(((1|A(U))*rho_0))            upwind phi;
    interpolate(thermo:psi)            upwind phi;
    interpolate(U_0)                 QUICK;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
what I want to do is substitute linearUpwind for all upwind terms in the code as to make it second order and therefore have to deal with less diffusion type inaccuracies. any suggestions??
Am I going about implementing a second order upwind scheme incorrectly?
I am using sonicFoam as a solver but I had the same problems with rhoCentralFoam
any help would be greatly appreciated.
jaason is offline   Reply With Quote
Old   June 11, 2014, 17:14
Default Same Problem
Yahoo is on a distinguished road
Hey,
Were you able to solve this error. I am getting the same one?
Originally Posted by jaason View Post
Hi FOAMers,
FOAM exiting
ddtSchemes
    default         Euler;
gradSchemes
    default         none;
divSchemes
    default         none;
laplacianSchemes
    default                 none;
    default                         none;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Yahoo is offline   Reply With Quote
Old   June 12, 2014, 06:25
Bernhard
Bernhard is on a distinguished road
Without looking I would say you have to supply "QUICK phi" instead of just "QUICK", because you need to tell the solver with respect to which variable it has to take the upwind values. This is a feature. The error message shown it the one you typically get when you have too little arguments in a line in a sub-dictionary.
Bernhard is offline   Reply With Quote
Old   July 2, 2014, 07:48
Ron
ron_OFuser is on a distinguished road
Hello everyone,
I am a newbie..
What is the difference between the following categories.
(1)
divSchemes
default none;
(2)
default none;
interpolate(thermosi) upwind phi;
interpolate(U_0) QUICK phi;
Any help will be greatly appreciated.
Thank you
ron_OFuser is offline   Reply With Quote
Old   February 6, 2015, 18:40
Dongyue Li
sharonyue is on a distinguished road
Originally Posted by ron_OFuser View Post
Hello everyone,
I am a newbie..
(1)
divSchemes
default none;
(2)
default none;
Thank you
the entry in interpolationSchemes is for some terms which need to get values from cell centres to faces. It includes all the terms in it.
In divSchemes, it only include the schemes for convections.
eg,
This will call upwind scheme when u wanna get HbyA's face value from the centers. U can only define it here instead of defining it in divSchemes, cause HbyA is not a convection term
Best,
sharonyue is offline   Reply With Quote
fvschemes, rhocentralfoam, second order accuracy, second order upwind, upwind
High Resolution (CFX) vs 2nd Order Upwind (Fluent) gravis ANSYS 3 March 24, 2011 03:43
2nd order conservative schemes taw Main CFD Forum 1 September 16, 2008 08:05
2nd order interpolation for NS solver Quarkz Main CFD Forum 6 July 15, 2005 22:50
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 01:31
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 15:33
