September 12, 2013, 11:44 |
Unusually high pressure at only one face
Aditya
Rep Power: 13 |
Hello
I am trying to simulate case of a centrifugal blower using MRFSimpleFoam. Every thing runs fine. The simulation is stable (I did not iterate till convergence: only 500 iterations). But the static pressure drops was wrong. While looking in to the pressure field, I found a very high and low pressure values on two faces just adjacent to each other on the surface of scroll. (picture attached). The values are way above the average values on the scroll. I am not quite sure what caused this. Any suggestions will be highly appreciated. Also can such a high value on one face effect the whole velocity and flow field ? I see some swirls which should not happen and these make the flow field very symmetric and causing swirls which finally are (probably) reducing the static pressure drop. |
September 13, 2013, 03:22 |
Nima Samkhaniani
Rep Power: 25 |
check your mesh with :
checkMesh
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
