BuoyantBoussinesqSimpleFoam solution diverging
Old   September 12, 2013, 09:36
Default BuoyantBoussinesqSimpleFoam solution diverging
Eshita Pal
EshitaPal is on a distinguished road
Hi all
I am trying to simulate the shell side flow of a shell and tube heat exchanger using buoyantBoussinesqSimplefoam solver. The boundary conditions are as follows:
Inlet: constant T, constant U, zerograd P
Outlet: zerograd T, zerograd U, p_rgh= 0;
I am using kEpsilon turbulence model.
The simulation diverges after few iterations (bounding epsilon diverges). If I switch off the turbulence model then the time step continuity value diverges. I have attached the log file. When I keep g=0 (i.e. no acc due to gravity) then the simuation converges perfectly. This behaves like forced convection.
Can anyone suggest what is the problem with g on?
EshitaPal is offline   Reply With Quote
Old   September 13, 2013, 17:15
Joachim Herb
jherb is on a distinguished road
I think this was already discussed in http://www.cfd-online.com/Forums/ope...roperties.html
So you probably have to modify or boundary conditions to use automatic switching between inlet and outles.
You could also try the transient BuoyantBoussinesqPimpleFoam solver.
jherb is offline   Reply With Quote
buoyanboussinesqsimple, natural convection, time step continuity
under-relaxation factors -> level of residuals Zigainer FLUENT 19 July 21, 2017 17:53
diverging solution in bubble rise shash FLUENT 0 August 11, 2012 17:39
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
solution singularity litonx OpenFOAM Running, Solving & CFD 1 February 21, 2007 02:32
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 14:37
