September 9, 2013, 10:07 |
Null drag coefficient - nuSgs and nuTilda
Rep Power: 13 |
Hello everybody!!
I use OpenFOAM since just a couple of weeks and I have problems with a simulation. I am trying to simulate a sphere inside a fluid at different Re. I want to use different models to learn about the differences and so, but at the moment I am just trying to fit the results that I get regarding the drag coefficient. I have set up the case to Re 50, 500, 5000, 50000 and 25000 using a DES-Spalart Allmaras model. The first two cases with the low Reynold numbers worked properly and got close-enough Cd; in the rest, the Drag Coefficient seems to go asintotic to 0, no matter how long OpenFoam iterates... In order to find the mistake I have done, I wanted to check the evolution of what in Fluent is called "Modified Turbulent Viscosity", but I didn't find it to compare. What I can check in ParaView are nuTilda and nuSgs, but nuTilda only is defined in the different patches always as zero, and I don't know what nuSgs is... Any advice would be very helpful. Thanks! |
drag coefficient, nusgs, nutilda |
