totalPressure boundary :Performance Curve (constant RPM)
Old   September 6, 2013, 12:34
Default totalPressure boundary :Performance Curve (constant RPM)
nash is on a distinguished road
Hi everyone,
i'm now working on simulation to generate a performance curve of a radial blower ( to be compared with the curve from manufacturer- see attachment) using simplefoam mrf (OF 2.2.0)
for the first simulation which i want to achieve maximum flow rate ( static pressure difference of inlet and outlet = 0) i used this totalPressure condition for both inlet and outlet (duct):
   type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 0;
    value           uniform 0;
the result seems to be good.
for the next simulation i would like to increase the static pressure difference to 50 pascal. Which one from below initial condition for outlet is the right condition to be made?
0/p for Outlet
   type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 50;
   type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 50;
   value uniform 50;
   type            totalPressure;
    rho none;
    psi none;
    phi phi;
    gamma 0;
    p0 uniform 50;
   value uniform 0;
or should i use other type of outlet and inlet boundary?
I tend to use totalpressure since i can set the static pressure hence easier for me to obtain the static pressure difference without need to do extra calculation etc.
please correct me if i did wrong.
thank you in advance
regards,
nash
nash is offline   Reply With Quote
curve, fan, performance, simplefoam
Feature Curve Definition and Boundary Splitting screech1987 STAR-CCM+ 6 November 12, 2017 14:18
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
